Cases Fractal Design Define XL launches
Discussion in 'Hardware' started by Guest-16, 2 Sep 2010.
  1. Guest-16
    Guest-16 Guest
  2. Jipa
    5 Feb 2004
    Good thing they made the new P180 that never came.
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    Ah-mazing, Fractal Design does some good work.
  4. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Nice looking cases for sure. Looking forward to the reviews :)
  5. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Can we haz a review plz?
    I have big plans for that case. If the lower compartment will allow for sideways mounted PSU and a rad a la TJ-07 I'm sold.
    Also, anything on the price yet?
  6. SlowMotionSuicide
    16 May 2009
    Got that myself, sweclockers says 1300 SEK so roughly 140 EUR. Now I'm really interested.
    A real man's case though, weighs in around hefty 18kg.
  7. ShakeyJake
    ShakeyJake My name is actually 'Jack'.
    5 May 2009
    Well I was saving for a 700d, but this may change my mind depending on reviews.
  8. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  9. Guest-16
    Guest-16 Guest
    Same as a HAF-X! ;)
  10. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Am I the only one underwhelmed by this? Just my opinion. It's just a bigger one of their previous ones, right?
  11. Fingers66
    30 Apr 2010
    Yes but with the removeable upper HD cage longer GPU's can fit than the R2/3. Also, the size increase means more space for water cooling.
  12. SlowMotionSuicide
    16 May 2009
    Precisely. Also, support for E-ATX means there's a nice spot next to the motherboard to fit a sexy 250mm tube res. And with any luck the bottom compartment will take a quad 120mm rad. Sure, TJ-07 and some LiLis will do that already, but this thing costs half the price, and still looks classy.
    Damn I really want some measurements on that thing, too bad it won't ship until october if I understood correctly:(
  13. Jipa
    5 Feb 2004
    Now lets hope they've got the build quality right and these don't smell like rubber factories when you pull it out of the box.
  14. Fingers66
    30 Apr 2010
    I bought a second hand one recently and there is no smell, I think it must only be a "new" smell.
    Saying that, one of the changes between the R2 and the R3 is reportedly a change from the bitumen sound deadening to a silicone material. I would assume therefore that the XL would come with this same material.
  15. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Looking forward to this case. I may try and build a rig in it at some point.
  16. Guest-16
    Guest-16 Guest
    They changed the rubber to silicone a while ago.
  17. Jipa
    5 Feb 2004
    Ok that's good to know.
  18. ShakeyJake
    5 May 2009
    But that's what I want from a case. :D
  19. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    I still don't get why, it didn't really smell at all, at least not on the two I've had (the first got damaged by the courier).
    Still, good to see they're expanding their range. I wonder if they'd consider designing a case with a double-glazed window, for those of us who like to see their hardware in action but also like a quiet machine.
  20. SlowMotionSuicide
    16 May 2009
    Considering they already paint the insides of their cases it would kinda make sense to offer windowed side panel for those of us who are not so confident with rotary power tools. If I decide to get this case I'm gonna have to find some local workshop to make the cuts for me.
    Also, I shot an email to Fractal last night about the inner space on the case, I'd really like to know if it's possible to
    1) put a slim triple rad on the top with 180mm fan removed, seems there might be enough space for swifty + fans without hitting the mb.
    2)mount the PSU sideways and put a quad 120mm rad into bottom compartment.
    Let's see whether they bother with a reply:rolleyes:
