Hardware Fractal Design Integra M 650W Review
Discussion in 'Article Discussion' started by Combatus, 13 Mar 2015.
  1. Combatus
    16 Feb 2009
  2. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    :D
    Not a bad little PSU for £62, not ugly looking either & semi-modular to boot.
  3. Guest-56605
    Guest-56605 Guest
    Nice to see a comparison included against the SilverStone SX600-G 600W (my weapon of choice :D )
    Great value PSU from Fractal :thumb:
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Oops! Thanks! Fixed now
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    Good to see more companies releasing compact power supplies, with the trend towards matx / mitx machines the standard size is just becoming more and more and laughable.
  6. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    It only has 1 pci-express power connector?
  7. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Wow! You guys really pumping out a lot of hardware reviews the last couple of weeks. something changed?
  8. Dogbert666
    17 Jan 2010
    No - check out the cabling table. The modular PCI-E connection you see in the image lets you connect a cable with 2 x 6+2 pin PCI-E connections on, and there are a further two bundled in the captive cables. In total, you can have a maximum of 4 8-pin PCI-E connections - plenty enough for a 650W PSU.
    Not especially! We're doing our best though, cheers!
Tags: Add Tags
