Cases Fractal design r3 and Hydro 100
Discussion in 'Hardware' started by staggerlee, 23 Dec 2011.
  1. staggerlee
    staggerlee What's a Dremel?
    2 Aug 2010
    Hi all,
    So i just brought a Fractal Design r3 with a Corsair H100. thinking the roof of the case with its 2 120 fans would be the perfect fit.
    sadly this isnt quiet. true. The spacing on the case has a little space between where the 2 fans would go. the h100 wants the fans right next to each other.
    What would you suggest. 1 sticking it on and getting 4/8 screws attached. Or go for a H60 or H80. to go in a single slot.
    Thanks
    S
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I'd say simply stick it on and have only 4/8 of the screws attached, so long as the fan's frame is reasonably rigid; it should hold the H100 easily. It'll also give you better cooling performance than the H80 or H60 will. In theory.
  3. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    +1 keep it and 4/8 screws should be pleanty to hold it
  4. staggerlee
    2 Aug 2010
    excellent! thanks for the replies.. i didnt much want to send it back and get a different one :D
    Now to put it all together.. properly back shortly with another foolish question!
    Thanks again
    S
  5. DoctorBeat
    DoctorBeat What's a Dremel?
    27 Jul 2006
    did you managed that? it still in place????
    I'm on the verge of buying that exact cooler and case
  6. Jasio
    Jasio Made in Canada
    27 Jun 2008
    You can always order a second set of screws from Corsair for a few dollars.
    But whenever buying an H100 it never hurts to look at the Corsair forums first to see their lists of recommended chassis before buying something with a 240 radiator.
