FRAMEstor Node 23 [7/18/07]
Discussion in 'Project Logs' started by scopEDog, 18 Jun 2004.
  1. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Wow thats sweet, and the video makes the effect look so much better than pics ever could. Keep it up
  2. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    You can use a flathead screwdriver to remove the position-lock springs from the flush-mount concealed hinges if you want a more even actuation without "slapping".
    I've been using them in projects for a while and the springs can be quite annoying.
    I am however left wondering why you didn't leave much space for cabling. Do you have any plans for cabling? For the thinner ones you may want to considering routing them underneat the motherboard to prevent them getting pulled by tubing when the outer shell hinges.
  3. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Thanks for the tip. Because of the thickness of the panels and the strength of the actuators the hinges are solid, although i know what you mean about slap.
    I have a plan for cabling and tubing :)
  4. Sheyr
    Sheyr What's a Dremel?
    3 Mar 2005
    :jawdrop: Very professional again. I'm really jealous!
  5. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    On this episode of "As the dremel turns":
    - What transformers do when nobody is looking
    - A progress report on my project
    - Find out about dremels new "pillow" attachment
    - Sneak peak into the next update
    -=Download here*=-
    *35 Meg DivX File w/ some slight vulgar language ^_^
  6. olle
    olle What's a Dremel?
    26 Nov 2005
    Fill cap!! or is it...? the black thinge for the next update...
    Great work... that sound when u open the case is real neat.
    Awsome job dude!!
  7. Matt_Ingram
    Matt_Ingram What's a Dremel?
    30 Mar 2005
    I reckon its a power connector, looks a lot like the ones someone used on a project made from a WWII vintage infantry radio. This is a really great project by the way, nothing quite like it around.
  8. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Thanks for that :)
    Yup thats right, its a power connector. Its going to help me bring some psu connectors to the outside. So it looks like I will be spending some time making some cables, should be fun i think :cooldude:
  9. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    FRAMEstor Node 23 Video Update 3
    On this episode:
    - A progress report on my project (External PSU time!)
    - Find out how long a noob machinist takes to make stuff
    - I become buddy buddy with M. Bison
    -=Download here*=-
    *53 Meg DivX File
  10. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    I like the moving bits very much :p
  11. LODRazor1
    LODRazor1 What's a Dremel?
    23 Sep 2004
    Interesting design, will be a great looking case if you can pull it all off. Good luck, I eagerly await the finish.
  12. Sphering
    Sphering What's a Dremel?
    31 Oct 2006
    For the record: We never broke up. We just took a 14 year vacation...
    Something like this going on here. Seems to be some serious timegaps in this thread.
  13. marauder16
    marauder16 What's a Dremel?
    30 Sep 2006
    some how I missed this one before, but I'll be following from now, awesome work :clap:
  14. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Wow I'm glad this project didn't die off like I thought it did. Since hardware has changed so much since you started on this case in 2004 ( :jawdrop: ) what are you thinking about sticking in this machine?
  15. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Ed, I worship the ground you walk on. That took a lot of patience, and I'm sure I could learn a few things from you! Wanna get together and make some crap sometime soon? :D
  16. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Thanks guys :D
    @Rocket733: I dunno, i've been giving it some thought since i will need to order soon. I was thinking dual core of course, but not sure if i wanna do sli or crossfire. I'll come up with something good :thumb:
    @Starbuck3733T: Matt...you bring the same beer from last time, and we can work on whatever you like! :hehe:
  17. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    UPDATES<><>UPDATES<><>UPDATES?
  18. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Dude, that sounds so awesome when it opens, it kind of makes me wish I had them in my case. :D
    Dude, stop spamming. This is the second thread that you've spammed with pointless update requests.
    What proves this as spamming is that this was updated TWO [2] days ago, yet you still spammed the thread with an update request.
  19. Snafu-X-
    Snafu-X- What's a Dremel?
    27 May 2005
    What sort of switch will you be using to trigger the actuators? I'm assuming you don't want it to open every time you power your system on. :hehe:
  20. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Actually that will be part of the next update...but if you look at the pic i posted up there ^^^ you can see the manual for it :D
