Storage Franken-pen
Discussion in 'Hardware' started by dave_salmon, 13 Jul 2010.
  1. dave_salmon
    dave_salmon What's a Dremel?
    24 Jun 2009
    So, I’m given a knackered USB drive with lots of important information on that hasn’t been back up. When plugged in, windows can’t tell what it is so it either asks you to “Insert disc” when clicked or shows as “unrecognised USB device”.
    So I have a closer nosey at the pen and see the case isn’t quite closed around the internals. I open it up and notice straight away what the problem is: The memory chip has been broken loose at one end and is hanging off the board.
    Two scraps of paper, two paper clips and a pair of fold away pliers later and BINGO! Pen recognised, data saved Franken-pen created:
    :hip:
  2. SmilerAl
    SmilerAl Terminate with extreme prejudice
    6 May 2010
    Mod of the month!
  3. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    If the traces are OK, you may be able to do the oven reflow trick and fix the key.
