Windows Free alternative to Itunes
Discussion in 'Software' started by Kronos, 24 Oct 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    After removing ITunes in the correct order as advised on an Apple page I discovered that it had played havoc with my system. So to cut a long story short it took a reinstall of Windows to sort.
    What I am looking for is a free alternative to the ever increasing size of ITunes just to put my tunes ETC on my Ipod.
  2. theshadow2001
    3 May 2012
    I don't have an ipod but I think you can use foobar to do this but it won't do it out of the box and will require some customization
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    Tried Foobar and all the faffing but not very user friendly.
    Went with CopyTrans Manager instead.
  5. Bumfluff101
    Bumfluff101 Minimodder
    10 Jan 2010
    Have you tried mediamonkey? I've found it much better than itunes
  6. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Seems Winamp will allows you to put music onto an ipod (don't own an ipod but I'm sure I sorted it out for my sister at one point).
  7. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    I used to use Media Monkey but now use MusicBee, which has some of the locked out functionality of MediaMonkey in the free version. Oh, and it looks a whole lot nicer too, especially if you use one of the free custom skins.
  8. techmonster
    techmonster What's a Dremel?
    24 Sep 2015
    there is software that i am using it for my iphone, CopyTrans Manager. I guess that would work on Ipods too !!
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    That is exactly what I am using mate thanks.
  10. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I use media monkey gold and been using it for a while now.
    Sent from my HTC One M9 using Tapatalk
