Development Free function compiling error in C++
Discussion in 'Tech Support' started by TheMusician, 30 Sep 2011.
  1. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    Tried to compile a free function (die.cpp and die.h) in Unix terminal and I can't seem to get it to work.
    The error:
    Code:
    Undefined                       first referenced
     symbol                             in file
    die()                               /var/tmp//cckddR2X.o
    ld: fatal: symbol referencing errors. No output written to a.out
    collect2: ld returned 1 exit status
    Die.cpp:
    Code:
    #include <math.h>
    #include <string>
    #include <iostream>
    #include <fstream>
    #include <stdio.h>
    #include <stdlib.h>
    #include <time.h>
    #include "die.h"
    int die(){
            srand (time(NULL));
            int number = rand() % 6 + 1;
            return number;
    The Die.h:
    Code:
    #ifndef __DIE_H
    #define __DIE_H
    int die();
    #endif
    I'm not sure what I'm doing wrong. Did I leave something out of my .h file? Any feedback is appreciated.
  2. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    You need an int main() function in your cpp since your'e trying to run from it. To define it really quickly, just say:
    Code:
    int main() {
        die()
    You don't need to put the main function in the header file.
    I'm not sure if you actually need this in a .h file, but I usually just put using namespace std;
  3. GoodBytes
    20 Jan 2007
    Yup, I am sure adding the main function will do the trick.
    "main" function is the first function being executed when you run any C++ program.
    (well almost all programming languages have a main sort of function, can be called differently).
  4. azrael-
    azrael- I'm special...
    18 May 2008
    A main() function is needed, but you also have to make sure you provide the correct signature.
    Something like this should do the trick:
    Code:
    int main(int argc, char *argv[])
      printf("The die was cast and the result is %d\n". die()); // To actually see the result of your function
      return 0; // Return code: 0 means the program returned without error.
