Apple Free iPad video converter
Discussion in 'Software' started by neocleous, 23 Sep 2010.
  1. neocleous
    neocleous Minimodder
    12 Feb 2002
    Hi all,
    Can any one recommend a free iPad video converter I have a couple of MKV's I would like to convert to play on an iPad.
    Thanks
  2. gavomatic57
    gavomatic57 Minimodder
    23 Apr 2009
    Handbrake clicky and then get Handbrake from here
  3. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
  4. stonedsurd
    11 Mar 2009
  5. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    Bumping an old thread instead of starting a new one. If I want to shrink my DVD's first and then encode them for IPAD use, what should I use for that? DVD Shrink? Or is there anything better/faster?
  6. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    I recommend this I haven't used the apple converters myself, but I know that most of the other tools they have do an excellent job. DVDVideoSoft Free Studio is completely free and in addition to getting the apple converters you also get video editing, DVD burning, youtube ripping, and other tools that you may find useful one day. The software package's evolved a lot since it's conception when it was basically a list of links ^^.
    here's a youtube of the latest version
  7. logan'srun
    22 Apr 2008
    thanks for the tip, but there was like 50 different programs on that link. I want to be able to compress a normal DVD to something like 700mb, and then I guess I can use handbrake from there, or check out in more detail your link. . . .
  8. wyx087
    15 Aug 2007
  9. Dae314
    3 Sep 2010
    Did you see the green button on the right? It's a big green rectangle and it says in in white text "Download Free Studio" and below that, "One installation for all programs" -_-. You click that, wait for the download to finish, and install the package. Every program gets installed, and you get an interface like the one in the video shows so you don't have to wonder how to access all the programs. The thing has a DVD ripper and a DVD burner plus apple and mobile device converters :p (although I would recommend getting virtualdub for video compression).
