Windows Free m4a to mp3 convertor software?
Discussion in 'Software' started by hanybanoub, 2 Jul 2006.
  1. hanybanoub
    hanybanoub What's a Dremel?
    19 Jan 2004
    Hi everyone,
    I've done a search here and on google, but only came up w/ Audacity, and after associating the lame encoder w/ it, I still couldn't export properly to MP3 (from an m4a file).
    Any other suggestions would be appreciated :)
    CHEERS!
  2. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    heya
    not sure whether or not it'l convert from m4a, but try 'mediamonkey' its completely free, looks nice and is a great little program!
  3. specofdust
    specofdust Banned
    26 Feb 2005
  4. hanybanoub
    19 Jan 2004
    Thanks for suggestions guys, I found a great free program called JHymn. It's brill!
  5. Shannon
    Shannon What's a Dremel?
    1 Jan 2006
    Did you really just want to convert from mp4 to mp3 or do you want to strip the drm off itunes mp4s?
    If your mp4 files are drm-free, I like to use dbPowerAmp
  6. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Stupid question but have you tryed renaming the file to .mp3?
    it was posted on a ipod forum that they used a diffent extension but it was still an mp3.
  7. alter_ego
    alter_ego What's a Dremel?
    26 Jun 2004
    itunes?
  8. hanybanoub
    19 Jan 2004
    Thanks for ur reply guys.
    I only wanted to convert mp4 to mp3, nothing more. I don't even know what drm-free is LOL :)
    I orginally tried to rename to mp3 but it didn't work.
    I don't have an ipod and loathe ;) Itunes (my mp3 is a Samsung YP-Z5)
  9. GiGo
    GiGo was once a nerd.....
    12 May 2002
    try www.dbpoweramp.com its a very good encoder and free, you'll have to download the seperate m4a codec which is availiable from the same site.
    I think that the newer version of the program limit it you the number of mp3s you can convert. If your after a version that will, then PM and ill sort you out with it.
    Regards
    GiGo
  10. Guest-16
    Guest-16 Guest
    m4a - winamp to wav - dbpoweramp mp3
  11. hanybanoub
    19 Jan 2004
    Thanks guys for your responses. GiGo YHPM.
  12. customh
    customh conflagration.
    22 Oct 2005
    So hanybanoub did JHymn work? I got a friend looking for this same thing. He wants to convert his protected m4a's too, not to get the drm off, but because he just wants his whole library in mp3 for his new phone that only likes mp3.
  13. hanybanoub
    19 Jan 2004
    It worked very well my friend, excellent program! Doesn't need to be installed either as it's a standalone :)
  14. customh
    22 Oct 2005
    Ah thanks, ill let him know. :D
