Windows Free Partitioning Software
Discussion in 'Software' started by Mckooy, 14 Aug 2008.
  1. Mckooy
    Mckooy New Member
    31 Jul 2008
    Following on from my problems here i want to partition my HDD and install Vista alongside xp. What is the best free software available that for partition?
  2. Hazardous
    Hazardous New Member
    21 Jan 2004
  3. Mckooy
    Mckooy New Member
    31 Jul 2008
    Just want to make sure I have this right. I have XP installed on my 150GB HDD, i want to install Vista Buissness 64 Bit. I will need to resize the exsisting XP (probally to about 20GB) then with the rest of the then unpartitioned space partition it to NTFS Logical. Then boot from the Vista CD and when installing choose that partition and it should just do it. Correct?
    thanks
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Yes, it is :)
  5. Gooey_GUI
    Gooey_GUI Wanted: Red Shirts
    3 Dec 2002
    Why only 20 gigs for XP? Take into account the amount of free space needed for virtual memory.
  6. ca_thy
    ca_thy New Member
    4 Nov 2008
  7. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    Why on earth would you need more than that to get XP to run properly? VM only really needs double your RAM value... so unless he's running 8GB or something more....?! Even then you'd probably have space spare...
  8. jbloggs
    jbloggs New Member
    12 Sep 2007
