Free Video Convertor (avi to mpeg)
Discussion in 'Software' started by jezmck, 20 Apr 2008.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hi guys and gals,
    can anyone recommend good free software for converting an avi file to an mpeg?
    Everything I've tried has been frankly crap, mostly due to actually spoiling the video by reproportioning (it's a word, honest) it or spoiling the colours!
    I really need it to be tested software, for use on WinXP.
    Thanks in advance, j
  2. atanum141
    22 Jul 2004
  3. ch424
    ch424 Design Warrior
    26 May 2004
    What have you tried? A friend uses SUPER and seems to like it.
  4. topdog555
    topdog555 What's a Dremel?
    31 Dec 2007
    I use SUPER too, great for converting files to play movies on the DS
  5. capnPedro
    11 Apr 2007
    I use MediaCoder to transcode pretty much anything into anything else.
  6. Glider
    Glider /dev/null
    2 Aug 2005
    Mencoder is available for Windows too. It's about as good as it gets on Linux, so I guess it is great on Windows too.
  7. wyx087
    15 Aug 2007
    i use StaxRip. it's really easy to use, all others are quite complicated, i find StaxRip is really easy, even got a wizard to walk you though it.
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    Thanks for all the suggestions everyone, SUPER has turned out the be the best of these.
    It's amazing how ugly they all are though!
  9. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    VLC. file>wizard. transcode from any format vlc plays to any format vlc plays.
  10. jezmck
    jezmck Minimodder
    25 Sep 2003
    doesn't look like VLC lets me fix the aspect ratio or crop the video, but good to know it's there.
  11. notatoad
    25 Jun 2004
    sorry, i thought you needed something that wouldn't change the aspect ratio.
  12. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
  13. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    I use the zune software, using the trick that makes the system pretend its a Mpg.
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
    yeah, sorry, I didn't explain that very well.
    I needed to fix the aspect, but some programmes didn't even ask, just forced it to 4:3.
    did you :read: ? how would that help me?
    The video I encoded is up at rebecca-wilcox.com/showreel
    I've not been able to crop and re-proportion it.
  15. jbloggs
    12 Sep 2007
    Apologies, I saw "mpeg" and automatically "assumed" DVD Video Files....
    However, I'm sure you will find some use for DVD Flick at a later time.....;)
    ________
    EXTREME Q VAPORIZOR
