Open Source FreeNAS question
Discussion in 'Software' started by happysack, 15 Jan 2012.
  1. happysack
    happysack goodateverthinger
    19 Dec 2009
    Hi there I currently have 2x500gb disks with all my data on.
    Could I install freenas on a 80gb primary disk and then share the 2x500gb disks as secondary disks over the network without the need to format them etc?
    If this doesn't quite make sense please let me know
    Cheers
  2. Fantus
    Fantus Nothing to see here...
    25 Jun 2010
    Unfortunately, no. FreeNAS has to format all drives before it can use them. This is something a lot of people have been asking for a long time but they still haven't done it. I can see why they haven't but it's still annoying.
  3. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    I tried something similar with Openmediavault, which is similar to FreeNAS. That won't do it either - you need to 'nuke' the disc first, ridding all partitions and FAT, then allow OMV or FN to do its thing.
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I've mounted already formatted drives in freenas. Unless they removed the option, as I haven't used it in awhile. The thing is though that for them to be reliable you need to use UFS. Select under disks add step preformatted and select the correct choice.
    Unless they have improved things don't use ntfs disks ever in freenas, it can read ok, but writing will wreck the data.
