Education Freesat Box, Satellite Cable Connection Issue.
Discussion in 'General' started by Mr_Mistoffelees, 21 Jun 2022.
  1. Mr_Mistoffelees
    Mr_Mistoffelees The Bit-Tech Cat.
    26 Aug 2014
    Simple question, when connecting the dish cable to the connectors on the back of an official Freesat 4K box, does the central conductor wire, in the coaxial plugs, need to be cut long to get a working connection? The central conductors on our cables seem to be quite short, they work fine with the Sky Q box but, the Freesat box complains of no signal.
  2. Mr_Mistoffelees
    26 Aug 2014
    Question answered on another forum.
  3. spolsh
    spolsh Multimodder
    4 Feb 2012
    ... and the answer was ?
    adidan and Gareth Halfacree like this.
  4. DeanSUNIAIU
    DeanSUNIAIU Minimodder
    11 Aug 2021
    On another forum. :grin:
  5. Mr_Mistoffelees
    26 Aug 2014
    Absolutely!
    A few mm beyond the end of the plug.
    adidan likes this.
  6. adidan
    25 Mar 2009
    Two timing barsteward
  7. Mr_Mistoffelees
    26 Aug 2014
    I'm waiting for a pair of new plugs to be delivered, as the Sky supplied ones are shite but, it looks like the above may not be the solution. Seems like I might need to buy a new LNB, which still costs less than a month of Sky, even at the £21 I've been paying.
  8. Gareth Halfacree
    4 Dec 2007
    Did you, by any chance, have Sky Q? 'cos if so, yes: you'll need a new universal LNB.
    EDIT: Just saw you said Sky Q in the very first post. So aye, sorry, it's new-LNB time!
  9. Mr_Mistoffelees
    26 Aug 2014
    We do have Sky Q until the 2nd of July but, as far as I can remember the LNB came with the dish and dates from when we got Sky+, around 8 or 9 years ago. I have gone ahead and ordered a quad LNB.
    Disclaimer: My memory is very unreliable…
  10. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    There's your problem, you forgot the wee sky fella nipped outside and changed your LNB's when you first had Sky Q
    Mr_Mistoffelees likes this.
  11. Gareth Halfacree
    4 Dec 2007
    Wot the long-bearded one sez: Sky Q requires a different LNB, and it's swapped out when you upgrade from Sky+. If you ask really nicely, they'll (usually) fit a combined LNB that does Sky Q and normal-non-proprietary satellite stuff including Sky+ - but you have to know about it in order to request it, or you'll get the Sky Q-only LNB instead.
    Absolutely nothing to do with gently discouraging Sky Q customers from switching to FreeSat, I'm sure...
  12. Mr_Mistoffelees
    26 Aug 2014
    You may well be right, a side effect of my mental health problems is poor memory.
  13. DeanSUNIAIU
    11 Aug 2021
  14. Mr_Mistoffelees
    26 Aug 2014
    Tried many different antidepressants over a number of years. Doctor agreed they do me little good, whilst causing severe, prolonged and frequent headaches, so I don’t take any.
  15. Mr_Mistoffelees
    26 Aug 2014
    New LNB fitted, box works.
    Gareth Halfacree and adidan like this.
