Freeware to view video capture device?
Discussion in 'Hardware' started by badders, 10 Jun 2008.
  1. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Okay Chaps, I'm sure there's something out there that will do what I want, I just can't find the right terms to pump into google.
    I have a Pinnacle 500-USB video capture device.
    What I want to do is view/hear the input to this (and make it fullscreen ;) )
    I don't need to record, I don't need to stream it to anywhere, I just want to see it.
    Needs to be freeware too!
    Thanks in Advance.
  2. iddqd
    iddqd What's a Dremel?
    6 Feb 2006
    Well, video capture devices sometimes have their own proprietary software that uses special decoding. The disc that comes with it includes the decoder, but to my knowledge, there is very little available for even fully licensed capture devices.
    Try looking for something about "video capture decoder" etc. That's about the most I can help. Good luck!
  3. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    windows movie maker? should already be installed on your system.
  4. ch424
    ch424 Design Warrior
    26 May 2004
    VLC can do it as well, I think.
  5. wsurritte
    wsurritte What's a Dremel?
    31 Oct 2005
    Yep, as long as you have drivers installed. Just goto "Open Capture Device" on the file menu. You may have to click the refresh buton to get your card to show up in the list.
  6. badders
    4 Dec 2007
    Thanks all - VLC won't play it so I guess it's a no-go.
    Cheers anyway!
  7. wsurritte
    31 Oct 2005
    Make sure your drivers are installed, then you should be able to use VLC. As far as completely "free" drivers, that will likely be impossible, but once the drivers are installed VLC should see it. Note the "refresh" part of my post above.
    Let us know,
    William
  8. badders
    4 Dec 2007
    Drivers are all installed correctly - got them direct from pinnacle's site.
    Tried refreshing, tried restarting.
    Looks like it's a no-go. Cheers though.
  9. Major
    Major Guest
    I use Windows Movie Maker. :)
  10. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    I spent soooo long trying to do this. There are loads of programs, but freeware seems to be hard to come by.
  11. wsurritte
    31 Oct 2005
  12. badders
    4 Dec 2007
    I didn't do anything different, but it's started working in VLC - Hooray!
    Maybe it just needed two reboots?
  13. Yanisin
    Yanisin What's a Dremel?
    22 Jul 2010
    I was sooo close, I got a couple problems using vlc player, the first problem is I can't align the hue with the video, I've tried, tit's impossible, the second problem I have is a 2 second delay during play back, if I remove that delay then there's no sound, please help.
    thanks Yanisin :thumb:
