Freeze Only When Booting?
Discussion in 'Tech Support' started by davidbacsik, 24 Feb 2008.
  1. davidbacsik
    davidbacsik New Member
    23 Apr 2006
    I did my first PC build this Fall, and I'm very very happy with the setup, except for one problem. The PC, after being "plugged in" (The power supply has a kill switch which I turn off at night because it has a light), will freeze twice during Windows startup, then start up normally, and be very very stable. I dual boot XP twice, one partition for desktop use and one for music-making, and it doesn't make a difference which I boot into. I find it very odd that this happens consistently. It only fails twice until it boots sucessfully, then I can turn it off (leaving the PS kill switch on), and turn it back on without any problem. I have no idea what's causing this, and I was wondering if there was an obvious cause for such behavior. I'd be happy to dig out specs if they would help.
  2. UncertainGod
    UncertainGod Well-Known Member
    18 Oct 2007
    Sounds like a power (warm up) issue or could be as simple as being in need of a bios update.
  3. davidbacsik
    23 Apr 2006
    Mmm. I think I'll try flipping the kill switch and letting it sit for an hour or two, and then trying to turn it on. Thanks.
  4. IAmATeaf
    IAmATeaf Member
    9 Jun 2006
    What PSU do you have?
    Have you run Prime95 on it to see if it's stable?
  5. Peter187
    Peter187 What is a Dremel?
    21 Jun 2006
    Stop turning you PC off at the kill switch and see if this helps, put T-shirt over the light at night for a few days.
  6. eeevan
    eeevan Dremel Master
    21 Oct 2007
    I encountered a similar problem awhile ago. Do as the above quote states, but flip the main power switch, then fully unplug the power connector - let sit for a couple hours.
  7. davidbacsik
    23 Apr 2006
    Alright, the problem persists. I have not touched the kill switch for about a week now, and every day, when i boot for the first time, I get the freezing. After that (for the rest of the day) I can turn it on and off as much as I please. It seems to be a "hasn't been touched in a long time" issue. I have a Hyper brand PSU, and will try to run a stability test this weekend. Does Prime95 specifically test power, because I ran system stability tests when I built the system, and they went for a full 16 hours before I threw in the towel.
    Thanks for all the suggestions.
    P.S.
    eeevan: Are you saying that you:
    1) Shut down PC from Windows
    2) Hit main power switch on front of computer
    3) Flipped kill switch on power supply
    4) unplugged power supply
    And that fixed the problem? I don't think this will work for me, because I moved the computer from room to room (doing that sequence exactly), and the problem persisted after the move. Nice for you, though. :D
  8. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Have you tried refilling the antifreeze tank?
    J/K :D
    Take a look at the capacitors on the motherboard. See if any of them are round at the top (should be flat).
    Do you have a spare motherboard to test with? If you do I would suggest that.
