Other Freezing pc
Discussion in 'Tech Support' started by therookie, 24 Jun 2011.
  1. therookie
    therookie What's a D.I.S.C.O?
    15 Apr 2011
    Hey my pc keeps freezing up and I don't know why, there doesn't seem to be any pattern either, weather under load or sitting idol... after manually rebooting I don't get any error messages.
    CPU Core 2 duo E7500
    Motherboard Not sure about my mobo its a dell studio 540
    RAM 3gb 800mhz
    Graphics card 5670 1gb
    Power supply 350w
    Operating system XP SP3
    At first I thought it was utorrent doing it running in the back ground but today I was only running chrome on youtube then it froze again.
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    I would say a problem with the operating system, probably showing its age seeing as we're talking Windows XP here. Be tempted to go the route of a fresh install if the system is so unresponsive that you can't do anything meaningful within windows.
    Have you installed any specific programs recently? Perhaps a virus scanner or other security software?
  3. therookie
    15 Apr 2011
    I'v only had the pc a few weeks, put a fresh install of XP on it (originally came with vista) when I got it and threw AGV free edition on it.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    how does it do in safe mode?
    i went to a machine yesterday, that if you went straight to normal (unsafe) mode, it wouldn't do anything, and took an age to load .
    went into safe mode, and machine loaded and ran with networking, perfectly, did a scan with malwarebytes, and removed over 200 threats in safe mode, but still wouldnt load properly in normal mode.
    machine was 7 years old so customer has decided that instead of spending to much on a repair, he was going to buy some new pc's - business customer
  5. therookie
    15 Apr 2011
    Haven't run it in safe mode tbh, however there's nothing wrong with load times etc, runs games fine ARMA, crysis no problems, scanned it the other day only tracking cookies were found.
  6. GoodBytes
    20 Jan 2007
    Check system temperature to make sure that all temperatures.
    Do you still have that Vista disk? If so, can you put it back (and upgrade it to the latest Service Pack)?
    I would like to eliminate the legacy OS problem. That is of course, if it's not a temperature problem.
    If it is, then new thermal paste is needed, and you should be good to go.
    Also, in the BIOS, make sure your SATA controller is set to IDE mode (also may be called: Legacy/Compatibility). Use AHCI on modern OS, such as Vista or Windows 7. XP doesn't like new stuff.
    This will create a performance degrease, and no support for SSD's, but if means a working system, then so be it.. until you decide to upgrade later on (if drivers exists). I would keep an eye at Windows 8 Public Beta, sometime next year. Not worth buying WIn7 now.. as Win8 is coming out end of next year (apparently, if no delays). If you are a student, your university or College might be registered to MSDNAA, which allows you to have all Microsoft software for free, except for Microsoft Office (OnNote and Project 2010 is there, though). All you need is your log-in info, which you can get from your school.
  7. therookie
    15 Apr 2011
    I'v checked the cpu and graphics card temperatures they are very low even under load.
    Yeah I still have the Vista disk, I put XP on because vista uses abit more ram and I'v never really gotten used to the OS.
  8. therookie
    15 Apr 2011
    In BIOS I see ATA or RAID configuration if I'm looking at the right thing.
  9. GoodBytes
    20 Jan 2007
    The reason why XP uses less RAM, is because it puts everything on your HDD instead. :)
    No mater how much RAM you have.. 128MB or 4GB, XP acts like you are low in memory (as it was deigned for system with under 512MB of RAM, which is what everyone had when XP was released... 1GB of RAM was unheard off, and is like saying I have 192GB of RAM, today)
    You should get used to Vista... well the newer Windows the better. Already the learning curve from XP to Win7 is high (trust me, at work we are migrating from XP to Win7.. and there are some regrets of skipping on Vista... due to it's rough start (no or badly done drivers by manufacture, and a push in customer to buy their newer product instead)).
    The jump to Win8 from XP will be even greater, and then you'll be left behind.
  10. therookie
    15 Apr 2011
    Think you're right, if it freezes again I'll reinstall vista. Should it keep freezing after that I'll start a new thread, thanks for the advice guys!
  11. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    If you're still having issues after a clean Vista install it'll definitely look hardware related, but you can keep going in the same thread.
    As mentionned it's a good idea for you to get used to Vista anyways.
