Electronics Frequency Shift Keying
Discussion in 'Modding' started by gindle, 1 May 2004.
  1. gindle
    gindle What's a Dremel?
    1 May 2004
    Hi Im new here, well i been watching the electronics board for some while now. I was just wondering if anybody had worked with frequency shift keying(fsk) at all? If anyone has then please post as i have a few questions.
  2. Pookeyhead
    30 Jan 2004
    FSK? You a Ham Radio operator?
  3. gindle
    1 May 2004
    No i jus want to be able to send a digital signal. And after talking to my electronics teacher he said that instead of just placing the digital signal on top of the modulated signal, I should use FSK. I was just wondering how you would go about transmitting and recieving the signal.
  4. Pookeyhead
    30 Jan 2004
    Oh OK. Just wondered as that's a Ham Radio data transmission method.
    I have no idea how to help you.. I was just wondering if you had a Ham Licence. Sorry... LOL
  5. gindle
    1 May 2004
    I don't know what a HAM radio is. I've seen em mentioned somewhere but it dont mean nothing to me.
  6. Pookeyhead
    30 Jan 2004
    Just a bunch of old guys sitting in sheds talking to other old guys in sheds in other parts of the world :D
    I like the challenge of global communication old-school style.. especially these days when communicating worldwide is so easy.
  7. gindle
    1 May 2004
    Sounds as boring as fishing to be honest, but hey everyman to there own.
  8. biff
    biff What's a Dremel?
    8 Jan 2004
    Fishing is only boring if you're not drinking.
  9. code81
    code81 What's a Dremel?
    12 Mar 2004
    Pretty simple for the transmitting end. Basically in Binary FSK what you need is to switch between 2 frequencies depending on whether a logic 0 or 1 is transmitted.
    As for the receiving end, you can go the non-coherent way. Using 2 band-pass filters see if either one of the frequencies is detected.
    What is your application? I suspect that ASK (placing digital signals on top of analog) would suffice.
  10. gindle
    1 May 2004
    I originally thought about just placing the digital signal ontop of the carry signal however there is a chance that the signal i shall be recieving wont be all tht great.
    What i want to do is place a webcam ontop of a rc car. So i need to be able to transmit the 2 data channels bk. So thought use fsk. And after speaking to my electronics tutor he siad tht would prob be the best bet. If you got any other ideas i very willing to hear them. Just tht finding a fsk circuit to base mine on, on the net aint the easiest. Cheers
  11. kt3946
    kt3946 What's a Dremel?
    17 Feb 2004
  12. gindle
    1 May 2004
    yea that helps alot. Just a case of find the time to research it fully and test a few ideas!! Im stuck right in the middle of my AS exams so it gonna be a while till i pursue all this but it shall be done. So the more information the better i say. It all appreciated. Thanks In Advance.
