Electronics Fried/Burned out rheostat? [Linear, Macro, Cheese opinions?]
Discussion in 'Modding' started by cderalow, 19 Feb 2002.
  1. cderalow
    cderalow bondage master!
    23 Jan 2002
    I built my rheobus using 5W 100Ohm rheostats from here , and its been together and running all of my fans for the past week with ease, but today the rheo that was controlling my cpu fan changed from its normal way of reacting: normally i could run the fan with knob turned to lowest setting and register fan at around 3000rpm, and at max, around 7900rpm... today it only works if knob is at maximum, shuts off if knobs is any lower... fan is rated for 1.8W.... anyone got any idea what the hell could be wrong?
  2. relix
    relix Minimodder
    14 Nov 2001
    nope! looks like you'll have to rely on linear, macroman or thecheesedude (in no particular order) :D
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Check the rheostat with a multimeter for open circuit, symptoms spell a break near the max end.
    Working back, a 100R 5W should stand 223mA (I^2*R=W) even without any safety factors, you're only pushing 150mA max so it should have been fine.
    Note rheostats can only run at their rating if kept fairly cool.
    Go solid state - you know it makes sense. :cool:
  4. macroman
    macroman The One
    3 Sep 2001
    Sounds like the pot is gone, probably the first turn on the resistive element burnt out. You could use the other , unused end instead. Of course the pot will work backwards then ;)
    It does beg the question - why did it burn out? Possibly you are overloading it.
  5. cderalow
    23 Jan 2002
    so just switch where the +v is soldered to one i dismantle it to make it better (a modder's work is never done.... might add some heatsinks while i'm at it to keep them cool)
  6. cderalow
    23 Jan 2002
    macro was right... switching to the other one and it works :) its now 100x nicer looking because 90% of the wiring is on a PCB.... so neat....
