Other Friend needs help trying to create video with his ps2
Discussion in 'Software' started by LightingBird, 11 Feb 2009.
  1. LightingBird
    LightingBird Minimodder
    25 Feb 2004
    Hey all,
    Basically, my friend is trying to make a Madden highlights video from his ps2. I believe he is trying to figure out a way to capture the video somehow, then get it on his computer, change it to avi or some format, then compile a video.
    Any idea how he can get the video? I was thinking maybe he could use a dvd recorder. Haha or maybe point a camcorder at this screen.
    Any ideas?
  2. opal
    opal Eh?
    21 Jan 2009
    You need a video capture card of some sort, plug your PS2 into that and you should be able to do it via that.
    I don't have much more info but Google is your friend
  3. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    as opal says, get a capture card. something like the huappuage wintv. it's got a yellow input jack on the back, plug the yellow output cable into it and then you can open it as a video source in your favorite editing program (even windows movie maker works)
