Modding Front Blowhole
Discussion in 'Modding' started by WireFrame, 16 Mar 2003.
  1. WireFrame
    WireFrame <b>PermaBanned</b>
    24 Feb 2003
    Anyone know where there's a good guide for an 80mm fromt blowhole?
    I saw one a while ago with some ghetto mod using half a funnel or something? Anyone else seen this? Any help would be appreciated
    :cooldude:
  2. T-Mug
    T-Mug What's a Dremel?
    16 Mar 2003
    it's not very difficult, drill a 80mm hole in the frond (i prefer 76mm) then you place the frond back. draw the hole at the metal, en drill the hole again...
  3. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
  4. Nexxo
    23 Oct 2001
    That's the ticket; a speaker duct (think studio equipment and boom boxes for car boot stereos) will do nicely. By the way, 76mm is the correct size for an 80mm fan. Remember that fan sizes refer to the diameter of the whole fan casing, not just the hole in the center!
  5. WireFrame
    24 Feb 2003
    I know you can buy proper plastic blowholes, I just saw an article which used half a funnel he bought. Wondered if anyone else had seen it.....
  6. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
