Sup guys? I've just finished building a new pc for my brother and it's all good - aside from one little annoying thing. The front panel audio cable doesn't reach the header on the motherboard, even if I try to send the cable directly across the motherboard. It's ludicrously short I could splice in some new wire, but if possible I'd prefer not to be quite as invasive. So does anyone know where I can get an extension for this? I've had a look around but as of yet I have not been able to find anything.
http://www.frozencpu.com/cat/l3/g2/...s-Wire_Management-Extension_Cables-Page1.html http://www.frontx.com/store/order_a.html Pretty sure you can find what you need there.
Cheers Bartaggio, I actually found the frozencpu.com site, but it is $5.99 for the cable and at least $15 for shipping, which seems a bit steep. The other website offers free shipping which is awesome. Thanks!
had the same problem when i built my computer bought one from scan heres the link http://www.scan.co.uk/Products/Akas...nsion-40cm-with-female-to-male-M-B-connectors
In a bit of thread necro, I'm after a female to female internal audio cable (HD Audio, not AC-97). Google says they don't exist, but they must be somewhere. +lots of rep for someone who can find me one in the UK!
Would this work? (Ebay Link) Can't really tell from the listing whether it is HD audio or not, but it may be worth asking the seller, if you're happy with it being from ebay and it being used.
Buy two male to female and make your own? Pin outs described here: http://www.frontx.com/cpx503.html If you don't mind buying from the states: http://www.frontx.com/store/order_ab.html (first link at top of page).
