Cases Front USB Ports Cause Restarts
Discussion in 'Tech Support' started by TheMusician, 25 Dec 2009.
  1. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    I think my front USB ports are shorted, because in the winter time, if you even simply touch them, my computer restarts.
    This is the first time i've had this problem with my new PC and this new case. My old case did this too. Any workarounds? Are the ports faulty? Is there a way I can ground the ports?
  2. Akava
    Akava Lurking...
    28 Jul 2007
    Sounds like a short to me, check the wiring, carefully, to see if there is any exposed cabling anywhere.
    Also, are you certain you have the plugged in the right place?
  3. philheckler
    philheckler Used to be a pc enthusiast
    23 Apr 2009
    Make sure you didn't plug the front panel usb cable to the 1394 firewire header - easy to do as they look the same...
