Electronics Front USB Ports On Me Lian-Li??
Discussion in 'Modding' started by LoopyJuice, 22 Feb 2002.
  1. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    hm well i tried this in the modding forums with no luck :( i hope someone can help me out, i have KuDoZ 7 mobo and it has headers for 4 more usb ports, whichi wanna use for the front of my new Lian-Li, trouble is there are two sets of five pins for each 2 ports like this
    whereas the lian instructions have it like
    and that is the amout of connectors there are :confused: tehre are 8 things to connect up but 10 pins
    here are some pics to explain..
    MoBo Manual -
    Lian-Li manual -
  2. macroman
    macroman The One
    3 Sep 2001
    Your mobo has two GND for each port whereas the Lian Li only needs one - just leave one of the GNDs on the mobo unconected.
    So for each port GND - GND, D+ - D+, D- - D- and +5V to USB power red.
  3. LoopyJuice
    24 Jun 2001
    ah ok thatnks a load man, i'll try that, man it had me all confuddled :rolleyes:
  4. LoopyJuice
    24 Jun 2001
    well i tried that but no go :confused: i connected them up properly and tried many times but they would not work, wen i plugged my mouse into them it lit for about a second then died and didn't work on them, mouse works fine tho
  5. FeebleUK
    FeebleUK What's a Dremel?
    22 Jan 2002
    i NEVER figured out how to do this, so i hjut thought sod it lol. Can somone draw an mspaint picture or somtthing?
  6. LoopyJuice
    24 Jun 2001
    i am gonna have another bash at it later, if i do it i'll post something mate
  7. FeebleUK
    22 Jan 2002
    k cool, im gonna do too, i might just plug them in randomly until it works.
  8. LoopyJuice
    24 Jun 2001
    i got it mate :D heres a crap diagram :-
  9. macroman
    macroman The One
    3 Sep 2001
    That's what i said do, you just needed to get the right GND. :cool:
  10. LoopyJuice
    24 Jun 2001
    yeah i see, just use the end gnd pin on each set of connections
  11. FeebleUK
    22 Jan 2002
  12. FeebleUK
    22 Jan 2002
    Damn this didnt work :(
    I have an abit kg7 raid, there is only one extra USB header. It looks like this
  13. FeebleUK
    22 Jan 2002
    any ideas?
  14. macroman
    macroman The One
    3 Sep 2001
  15. LoopyJuice
    24 Jun 2001
    yeah feeble i had 2 extra, they are just grounds which are not needed
  16. FeebleUK
    22 Jan 2002
    AWSOME!! htanks alot, and macroman, why you dont come in irc? unsociable :)
