Modding Frosted ccfl
Discussion in 'Modding' started by Jokkocze, 5 Feb 2005.
  1. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    Just curious if anyone frosted their ccfl's.. I think it would look good
  2. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    How do you mean?
    If you mean, using a generator, and sand. Then, it would just break the glass.
  3. Jokkocze
    16 Dec 2004
    no, I meant more like sanding it.. hehe :p (not really frosted, but almoast)
  4. dj_2004
    dj_2004 What's a Dremel?
    9 Oct 2004
    not a bad idea, hope somebody has done it.
  5. Jokkocze
    16 Dec 2004
    hmm.. well, then I'll do it now
  6. Jokkocze
    16 Dec 2004
    Ok, it's done
    Not as much light, but whole thing's glowing!
    The result:
    [​IMG][​IMG]
    the upper one on the pics aint sanded
  7. Jokkocze
    16 Dec 2004
    gosh.. no replies at all.. dang!
  8. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    I don't see the diffrence.... :worried:
  9. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    Something like that would be hard to take a picture of, try to take a much closer picture, I can see what your talking about, how now instead of just raw light, its more of something that wouldn't burn your retena's looking at. Got to be some cool things that you can do with that, such as mounting it in places you would see the actual light, such as external applications.
  10. Jokkocze
    16 Dec 2004
    hmm.. I'll put em' in a case with a broken mobo, if that's what u meant :p
  11. Jokkocze
    16 Dec 2004
    ok, pics taken:
    Frosted
    Not Frosted
  12. theflinger
    theflinger What's a Dremel?
    21 Mar 2004
    much better :D
  13. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    Comparatively, the light loss is minimal. Awesome... how much sanding did you do exactly? I wish to replicate your results.
  14. TroubledMind
    TroubledMind What's a Dremel?
    9 Aug 2004
    I reallly like the way it looks, it would be perfect for theme based mods and external mods.
  15. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    you could also use that glass frost stuff in a spray can, i did a flat piece of plexi and 2 of my window pain in the basement and it works wonders.one good thing about it unlike sanding that stuff can be removed with alchool so all you'd have to do is spray the acrylic tube of the ccfl :D
  16. Emon
    Emon What's a Dremel?
    14 Jun 2004
    You can safely sandblast a CCFL. CCFLs for PCs are CCFTs encased in an acrylic tube to protect them. You can sandblast your hand without breaking skin (depending on the sand and PSI...don't try it, dumbass), you aren't going to break a CCFL.
  17. Jokkocze
    16 Dec 2004
    Did'nt sand very much.. I'll put up a couple of pics of it later, when I get new batteries for the digicam
  18. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    I like the effect it reminds me of doom for some reason :blah:
  19. TheMuffinMan
    TheMuffinMan Minimodder
    26 Apr 2004
    There's a difference between sanding the actual cathode and the tube it's in. The actual cathode would probably snap when you apply the pressure on it, unless you were really light touched, but you wouldnt get the results. Sanding a plastic casing wouldn't affect the cathode itself, just diffuse the light as it exited, so sandblasting it would be fine
  20. TranZam
    TranZam What's a Dremel?
    2 Feb 2005
    I think it looks awesome. If you were worried about mucking up the unit itself, you could just buy an acrylic tube just large enough for the unit to fit inside, then you could experiment with different ideas and not ruin the tube itself. I'm thinking a double helix of opaque area on a clear tube... would look insane!
    -TZ
