Case Mod - In Progress Frozen Grey By Twister [COMPLETED]
Discussion in 'Project Logs' started by twister7800gtx, 13 Oct 2015.
  1. twister7800gtx
    twister7800gtx Minimodder
    2 Nov 2011
    Hi guys , after a little break I decided to begin a new mod with the wonderful Corsair 780T, it is amazing with a nice estetic and enough spacious to host a good mod. So, let's start with the presentation of this mod and with a big thanks to Corsair, Asus and Drako.it, without them this couldn't be possible.
    and today I received a very awaited package: the great 780T Corsair white.. without this I have no idea where to start
    a quick unpacking...
  2. twister7800gtx
    2 Nov 2011
    Today I'm starting to disassemble..
    ok NOW the simple mod for this case is a change the standard Atx in Reverse ATX!
    This is a quick photo of the back
    and now i cut...because I do not want the power supply top
    and this a small idea for the join the pieces?
  3. twister7800gtx
    2 Nov 2011
    i try to finish and use a black plexiglass... it's feel better
    and the inside and i use m3 screws
  4. twister7800gtx
    2 Nov 2011
    Now beginning to cut those parts that are bad in my opinion
    much better .... no?
    and a little progress ... I chose the new color for the 780T ! frozen grey?:D
    It is a mix of metal gray with a mattifying
  5. twister7800gtx
    2 Nov 2011
    I decided unfortunately for various problems to remake the rear...
    This is a new black rear ^^
    without my cnc I not know how to do ....
    small test with the cover white, after the painting ...
  6. twister7800gtx
    2 Nov 2011
    'm back!
    Now we cut those horrible edges of the 780T standard ... so as to homogenise with the plastic ...
    little mod for front!
    fix the psu...
  7. twister7800gtx
    2 Nov 2011
    After having replaced the inside..... fixed everything with these steel bars
    and this is a result!
  8. twister7800gtx
    2 Nov 2011
    The new support motherboard..
    Test with a old motherboard x79
    like satin!
  9. twister7800gtx
    2 Nov 2011
    now work on a partition lighted with my classic " liquid carved":D
    and now cover acrilic white translucent
    now misses white light!
  10. twister7800gtx
    2 Nov 2011
    Next Update! Try to fix the partition
    with the closure
  11. twister7800gtx
    2 Nov 2011
    then attach the led on the partition..
    this is a result without liquid ..
    I lose my eyes :lol:
  12. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    :jawdrop:WOW
    How much deep are the water channels ?
  13. twister7800gtx
    2 Nov 2011
    6mm :thumb:
  14. twister7800gtx
    2 Nov 2011
    Tonight i mod the pump...!
    2x Laing DDC ! with a little cover!
    One shot of radiator..
  15. leonetu
    leonetu What's a Dremel?
    29 Oct 2013
    Nice - subscribed!
  16. twister7800gtx
    2 Nov 2011
    tnx
    Today I installed the hardware and i proceeding with liquid cooling..
    I used chrome tubes..
    I'm trying to create a tank original .....
  17. Derick
    Derick Senpai Studios
    26 May 2012
    Clicked thread just because I saw who the OP was, was not disappointed.
  18. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Stunned, you sir are a master craftsman. moooooore! :p
    J.
  19. twister7800gtx
    2 Nov 2011
    Thank so much!
  20. twister7800gtx
    2 Nov 2011
    Today is time to sleeving... and testing colors!
    few colors :D
    This color is beautiful:blush:
