Case Mod - In Progress Frozen Throne - [COMPLETED]
Discussion in 'Project Logs' started by ToddK, 20 Apr 2015.
  1. ToddK
    ToddK What's a Dremel?
    3 May 2014
    :thumb:
  2. ToddK
    3 May 2014
    Small update. Getting some holes cut for the power button and power light.
    Laying down some primer on the printed bits.
    Some metallic paint for the gate bars including some dry-brushing of rust.
    Coming along. Slowly but surely.
    And designing up a custom mount for the power light & switch.
    And some fitting & tweeks later and we're done.
  3. ToddK
    3 May 2014
    Tear down & painting has commenced...
  4. ChrisHowell
    ChrisHowell What's a Dremel?
    29 Aug 2015
    I'm liking all of the sheet metal work and skill with Acrylic. The build is looking great too. nice one!
    Can I ask what tool you are using to cut the sheet metal? (your result was super neat, I'm envious :))
    And also how you engraved the top of the acrylic?
  5. OmightyOne
    OmightyOne Minimodder
    7 Nov 2011
    Looking forward for more pics!
  6. ToddK
    3 May 2014
    Thanks! :thumb:
    The sheet metal work has been a combo of dremel for cutting and some tin snips.
    The acrylic engraving has been done with an exacto knife with a ruler. I just had a print out of the image taped underneath. For the most part I tried to stick to straight lines.
  7. ToddK
    3 May 2014
    As you wish! Here's a preview of the paint. Hoping to reassemble this weekend.
    I wish my camera skills were better to do it better justice. I'm really loving the blue/chrome combo.
  8. ToddK
    3 May 2014
    A few more shots of the metal flake paint in the sunshine.
    Hopefully reassembling the case tomorrow. :clap::naughty::rock:
  9. ToddK
    3 May 2014
    Reassembly commenced today. Just one of those days where putting stuff together scuffed up the paint a bit. *sigh* So reapplied some paint in a couple of areas and need to wait for that to dry.
  10. ElectricKite
    ElectricKite What's a Dremel?
    13 Jan 2015
    It looks great, Todd! I'm thoroughly looking forward to seeing how this build ends up. Keep up the good work.
  11. ToddK
    3 May 2014
    Thanks! :thumb:
  12. ToddK
    3 May 2014
    Crackle paint! Working on making the outside look dilapidated. Crackle paint is a combo of white school glue and fresh paint over top while it's still wet. Cracks as it dries.
    Still more dry brushing & such to do, but here's a start.
  13. ToddK
    3 May 2014
    Some further work on the paint this weekend. Some dry brushing on the front & sides. Really starting to come together.
  14. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    Poking my head in here just to say I'm still watching and still enjoying! (It's easy to get discouraged with no comments).
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking good Todd.
  16. ToddK
    3 May 2014
    Very much appreciated!
    Thanks!
    Getting much closer to completion now. Some 'blown snow' to air brush on top and flags to create. That should be about it.
  17. ToddK
    3 May 2014
    Starting to do some test airbrushing of the blown snow. Good thing I'm trying it out on some scrap first. Not a bad first attempt, but my skillz need some work.
    Pulling up a reference from the video.
    Day 2 of practice:
  18. ToddK
    3 May 2014
    Just continuing to work through the technique. Large sweeping motions from outside to in for the blowing snow. Paper template for the sharper edges in the middle.
  19. ToddK
    3 May 2014
    Snow Paint!
  20. Cheapskate
    13 May 2007
    looks great.:D
