FSB 2 high?
Discussion in 'Hardware' started by burnoutuk, 13 Apr 2003.
  1. burnoutuk
    burnoutuk What's a Dremel?
    18 Feb 2003
    :waah: Ok i think ive done a stupid thing i set my fsb 2 166 and its a xp2000 (133fsb) it now wont start up. The computer starts but nothing on screen (Monitor stays off) on my 'D-bracket' From the lights on the back and from the manual it says "Early chipset initialization"
    Any ideas whats wrong and how to fix it?
    Thanks
    :wallbash: :wallbash:
  2. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    you OC'ed too high...
    restart the cmos. look in your mobo manual to find the cmos jumper. then turn off the system, take the cmos battery off, switch the jumper for a couple of secs, then put the battery back, switch the jumper back and start your computer. all cmos settings will be to factory defaults and you'll be able to start your computer again ;)
    I've done it 4 times since yesthurday :D
  3. burnoutuk
    18 Feb 2003
    Thank you thank you thank you :D Ill try it now
