Other FSX graphics are awful??
Discussion in 'Software' started by geoboy333, 28 Jul 2011.
  1. geoboy333
    geoboy333 Sometimes I say something bright...
    28 Sep 2009
    Hi All
    I recently reinstalled flight simulator x, only to rediscover why I uninstalled it in the first place. Can anyone back me up that the graphics are bad or is there a problem?
    Here is a screen shot of the graphics. TBH the look no different from 2004. Is this normal?
    http://imageshack.us/photo/my-images/713/flightsim.png/
    the frame rate is also terribly low, I expected my rig to handle such low res games with ease.
    Any help>
  2. Shichibukai
    Shichibukai Resident Nitpicker
    29 Sep 2009
    I think that's actually normal. The Flight Simulator series have never really impressed me with graphics, they're a lot of scenery addons for sale, but imho your money would be better spent on something like LoMac or Digital Combat Simulator, sadly those are only for military aircraft and don't offer the variety of FSX.
  3. GoodBytes
    20 Jan 2007
    Well I can see that your graphic card can't handle Windows Aero... So I am even surprised that you have this nice graphics on your old computer. Old Laptop?
    You should definitely install the game on your desktop (what I see on your signature), for the best experience
  4. geoboy333
    28 Sep 2009
    No it's the rig in the description, and it can handle aero, it just automatically turns off when i start FSX. It handles everygame I throw at it 100FPS or more.
  5. geoboy333
    28 Sep 2009
    all settings are at max in game, it crawls along and it looks terrible.
    My rig can handle all other games with ease. WTF is going on?
  6. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    I suppose it's like trying to play space invaders in hd. It just isn't going to look good no matter what
  7. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    I remember FSX and basically it looks good from up high and pretty crappy near the ground.
  8. Zener Diode
    Zener Diode User Title
    13 Sep 2009
    Run in fullscreen, not windowed for starters. I heard performance isn't as good when in window mode.
    EDIT:Also there is a service pack I think, it comes with Acceleration expansion pack or you can dl it. It improves multi core performance.
  9. geoboy333
    28 Sep 2009
    Acceleration Expansion pack is installed. I do normally run in fullscreen (doesn't make a bit of difference) but print screen wasn't working when in fullscreen and I couldn't get either xfire nor steam screenshots to work with it.
  10. GoodBytes
    20 Jan 2007
    Ok, go to Nvidia website, and get the latest drivers from there.
    Install them, but click on "Custom' install. And uncheck any 3D Nvidia stuff.
    Then, check the box the box to tell the setup to perform a clean install.
    Once done, restart your computer, and download and install Microsoft latest DirectX redistributable file:
    http://www.microsoft.com/download/en/details.aspx?id=8109
    Now see if your games runs fine.
    geoboy333 likes this.
  11. Zener Diode
    13 Sep 2009
    Ok. There is a function to take screenshots in FSX, I think the key is "V" but you can assign one in controls. It will save to some directory in My Pictures folder or something.
    Anyways the graphics in FSX, especially to someone who has played any modern games, are pretty bad. The planes are OK (some third party ones at least), but the scenery sucks in general.
    FSX is a good few years old now, and even at the time it was poorly designed to maintain compatibility with FS 2004 addons or something. It doesn't do a good job of utilising multi core CPU's and yet remains very CPU dependent. Powerful graphics cards don't help much, and SLI/Crossfire doesn't help at all as far as I'm aware. Because of the size of the map they can't afford to do it in detail, and even if they did the graphics engine isn't designed well enough to render it fluidly. In any case, FSX is not a game really (not that it is the best simulator either), and so the cockpit has a higher priority over ground scenery.
    In certain conditions though, I find it looks OK for an old sim, a bit dated but whatever.
    FTX provide some decent freeware scenery here:http://fullterrain.com/freeware.html
    and some time-unlimited demos here:http://fullterrain.com/product_demos.html
    To get rid of the 2D clouds and to get nicer water, REX (not free) seems to be the way to go:http://www.realenvironmentxtreme.com/
  12. geoboy333
    28 Sep 2009
    This helped somewhat, it looks a tiny bit better (still a bit dated though) but the textures load correctly at least and it runs smoother. me want FSXI now :/
    Thanks goodbytes, +rep
  13. GoodBytes
    20 Jan 2007
    If not, you can try older Nvidia drivers, maybe something screwed up.
    You see, There is just so many games they can support and optimize the game for, some no more supported games (older games) might cause performance issues. So you can try jumping back several versions of Nvidia drivers.
