Hey guys, first time in a long time that I've come crawling for help! Bit of background - I've started working on the development of some web frameworks that need various versions uploading to the same FTP site. I was trying to create a batch file that connects to the FTP then asks what to name the new folder before uploading the contents. The FTP will always be the same - just want it to ask for the new folder name to create then upload to. Bit complex? All help and advice welcomed!
1) asking user for input : Code: set /p Folder="Folder on FTP Server:" 2) create a file containing FTP commands using echo statements, where you will use the %Folder% variable in place where you are creating the new directory or changing the working directory to it. Code: echo Do this >commands.txt echo cd %Folder% >commands.txt echo Do that >commands.txt 3) execute the ftp command with the file you just created using echo statements via redirection to the standard input Code: ftp -s:commands.txt ftp.server.com
