I have a motherboard that has gone down. Buying a new one with win2k as the op any good ones? Also if I keep the harddrive from the old motherboard insterlation will win2k work. Thanks
There have been lots of threads regarding motherboard choice recently. For a few ideas see: http://forums.bit-tech.net/showthread.php?s=&threadid=10602 http://forums.bit-tech.net/showthread.php?s=&threadid=10344
thanks for the post. good idears will go for the gigabyte. but still i have the problem with the existing harddrive, will i need to re-install win2k for the new motherboard to work?
gigabyte is a good choice... its always worth doing a new installation as it will set up the os just for that mobo and other pc hardware, but you can always try not reinstalling... but whats against reinstalling anyway?? only takes 12mins or so....
