News Fujitsu Launches Biodegradable Mouse
Discussion in 'Article Discussion' started by arcticstoat, 25 Jan 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    How do they define biodegradeable? I've never understood this. Recyclable, ok, but I can't see us putting our used electronics in the composter somehow.
    All else aside, the other mice that visit the composter might get jealous... ;)
  3. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    If it is truly biodegradeable, can I bury this then and leave it there, safe in the knowledge that NOTHING is hurting nature?
    Recyclable, sure. Biodegradeable? Pics or it didn't happen tbh.
  4. Jqim
    Jqim What's a Dremel?
    10 Jan 2011
    So, how long can you leave it on your desk before it turns to sludge?
    Does it degrade quickly after a certain point i.e. fine for 5 years then bam it's all 'earthy' and needs to be composted. Is it a slow process where it slowly falls apart giving you months of flaky use?
  5. DriftCarl
    DriftCarl Minimodder
    2 Nov 2004
    The mouse will just break apart naturally after some years, most likely while on a landfill site.
    If you use the newish tesco bags you will be familiar with it also. If you wrap something in a tesco bag and put it away for storage, when you come back to it about a month later, the bag will be falling to bits.
    It all depends how long you expect your mouse and keyboard to last. my MX518 has lasted for years, along with my G15 keyboard. It may be cheaper to make those biodegradable ones in a 1 on 1 comparison, but how many sets of those would I have to use for them to last as long as my logitech ones?
  6. yuusou
    yuusou Multimodder
    5 Nov 2006
    I'm still waiting for the edible kind.
  7. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    I suspect that only the shell is biodegradable, while the electronics inside are still as harmful as ever. Like the posters above, I am inclined to say that we would be better off making our tech recyclable rather than biodegradable.
  8. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Your cat has the edible kind.
  9. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    I am sure the "biodegradable" and fully recyclable part means that the electronic bits can be recycled and then the shell can be chucked to biodegrade.
    Depending on the properties it is probably either only biodegradable in water, or with UV. My wife's Yoga mat is that way, UV light will begin breaking it down. Safe to use outside a bit, but a few weeks of constant sun is going to make it start to fall apart. A lot of vegetable based platic alternatives will only begin biodegrading if exposed to water (such as in a landfill), and it isn't immediate.
  10. dangak
    dangak What's a Dremel?
    27 Sep 2010
    Wow, that's pretty far out. I wonder if sweaty palms make it degrade sooner.
  11. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    what i want to know is if this mouse is really biodegradable, wouldn't that mean after many years of use it'll start to physically degrade? i wouldn't want to take my hand off my mouse to find arboform residue on my hand
  12. mattbailey
    mattbailey What's a Dremel?
    26 Dec 2009
    I'll ask my cat to save you one!
  13. crayfish
    crayfish Amazing scenes!
    3 Dec 2002
    There are palms out there so sweaty that this wouldn't last 5 minutes under.
  14. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    So how long does it take to "degrade" then?
    10, 20, 50 100+ years?
  15. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Considerably less long than plastic.
  16. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Though it's a novel concept, that's damn expensive for a basic mouse. You can get a MS Mouse for like, $4.
  17. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    Good to see one manufacturer making a planet conscious environmentally friendly effort, I wonder how long long they will do it with other products of theres.
    We could do with more products making use of Arbofoam and Biograde, like keyboards and gamepads, consoles, headsets, cases and enclosures of all descriptions, printers and to other household things like cooking utensils, smoke alarms, tv's and so the list goes on.
    Hopefully other manufacturers will take this example and follow suit.
  18. kenco_uk
    28 Nov 2003
    I think I could biodegrade this all by myself:
    The next big thing... edible motherboards..
    eddtox likes this.
  19. eddtox
    7 Jan 2006
    I would :D
    +rep
  20. LionheartDamacy
    LionheartDamacy What's a Dremel?
    27 Jul 2010
    I think the point is that the would-be-plastic parts are now biodegradable (whereas in the past, these pieces would just sit in a landfill for ages). The electronic parts are the same, but they are recyclable--so essentially, the impact of this mouse on nature is minimal. The whole thing obvious isn't biodegradable, as the article indicates.
    @Ph4lanx: If you do a google search, you'll quickly find Arbofoam degrades into the same constituent parts as wood since Arbofoam is made of lignin (a waste product from paper manufacturing and an entirely natural component of wood). This probably tells me Arbofoam will last a pretty long time unless exposed to less-than-normal circumstances such as extreme humidity.
    I couldn't find much on Biograde except that, unlike Arbofoam's lignin, Biograde is based on natural resins. In both cases, Biograde and Arbofoam are non-toxic, non-polluting, fully biodegradable, and yes.. if you leave parts made from Biograde or Arbofoam in the ground, it won't hurt nature at all.
    Just make sure to recycle the inside bits! But that should be completely obvious... right?
Tags: Add Tags
