News Fujitsu launches hands-on custom PC building service
Discussion in 'Article Discussion' started by brumgrunt, 5 Jul 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    I would be interested in the laptop as they are always such a pain, but its good idea however I'm sure if you do anything in computing in college you get taught all this anyway?
  3. TheLegendJoe
    TheLegendJoe Syntax error
    28 Oct 2010
    Sounds like a good idea! Not just because I work for Fujitsu... but I would have liked the option to do that when I first built a PC, I only had YouTube and text to go off!
  4. CampGareth
    CampGareth What's a Dremel?
    15 May 2009
    Having just completed Computing A level with OCR, you don't. We didn't even get to take the side off a prebuilt computer. You do learn bits about the internal structure of a CPU and HDD plus a little about RAM but that's it and it really doesn't qualify you to build a computer (it's also partially wrong, the boot file supposedly loads user preferences? Rubbish).
  5. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    I wonder how much of a premium they will charge for this. As opposed to the premium you have to pay (effectively nothing) for getting hold of a screwdriver, taking the side panel off, having a look at the bits inside and doing some research online.
    I know this sort of thing isn't aimed anywhere near me - or your average bit-tech reader - but it really isn't that hard these days. If you're building a system from scratch, the only way you can really damage the hardware - aside from the CPU/CPU socket - is to really jam things into a socket they're not designed to fit into. You'll know if a socket isn't designed for the cable/widget in your hands because it'll either be: a different colour, a different shape, or can't be easily inserted.
    I can't help but be cynical, because it really is like playing with lego these days.
Tags: Add Tags
