Peripherals full size blue tooth keyboard.
Discussion in 'Hardware' started by dave_c, 1 Dec 2012.
  1. dave_c
    dave_c Minimodder
    31 Jul 2009
    im looking for a full size (like my pc) keyboard which i can use with my android tablet and phone. have found a couple via good ol` google but they cost a small fortune.
    anyone know where i might find a good`n? for a Decent price <£40 not massively bothered about a numpad but im writing large docs and cant really afford a new laptop atm.:waah:
    thanks in advance.
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Have a look at KBT Pro. Yes it is much more cost than £40 but its a very high quality. I don't know of anything cheaper thats rated to work with everything.
  3. dave_c
    dave_c Minimodder
    31 Jul 2009
    No use what so ever mate, First, i could buy a bleedin laptop for the price of that thing. Second it US based (my fault should have specified i want a UK keyboard) and lastly (and least-ly) it looks like a keyboard you buy from asda (wal-mart) for 5.99.
    honestly cant image anyone wanting to spend that on a keyboard that looks like that, no offence :D
  4. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
    Oh Dave... your lack of knowledge and willingness to criticize is astounding
  5. dave_c
    dave_c Minimodder
    31 Jul 2009
    didnt mean it to sound harsh but, i did say in my initial post that i couldnt afford a new laptop and that keyboard alone is $180 for which is actually twice the amount i would pay for a laptop to do the same thing and you gotta admit the things fugly. i have used a US keyboard before and it was confusing swapping between UK and US keyboards.
    im not spotting the lack of knowledge? suspect easily astounded.
  6. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    You said you were writing large documents, and therefore will want a good keyboard. Personally if that was my use I would put typing over looks.
  7. dave_c
    dave_c Minimodder
    31 Jul 2009
    haha, true, did say it was the least :D.
    honestly didnt mean any offence, but WAY out of my budget im afraid bud.
  8. KidMod-Southpaw
    28 Sep 2010
    You ever used a mechanical keyboard mate? Come to my house in Wigan and try my Poker with MX blues. :D
    At Scan, you can get a Cm Storm mechanical keyboard for just over £50 if that's more reasonable. Do some research on mechanical boards, you'll thank us.
    Edit: Ignore this entire post. I didn't notice the bluetooth part.
  9. fuus
    4 Dec 2010
    Please excuse my quick jump to criticism.
    Within your price range I think I would go with either Apple's offerings or one of Logitech's thin keyboards which I think can be had for under £50! :)
  10. fdbh96
    29 May 2011
    For a mobile bluetooth keyboard, I recommend the logitech tablet keyboard. It lasts for ages on battery, is light and comes with a case that doubles as a stand.
  11. dave_c
    dave_c Minimodder
    31 Jul 2009
    can honestly say i have no idea on that one, iv just written about 3000 words on a £5 keyboard and i cant really see myself spending more than that anytime soon. what exactly makes these mechanical keyboards so good?
    thanks ill take a look at the logitech stuff, wont buy apple on principle. :D
