Functional huge keyboard - Update 05-APR-2006
Discussion in 'Project Logs' started by ATOG, 27 Jan 2006.
  1. offroadracer789
    offroadracer789 What's a Dremel?
    9 Dec 2004
    *plans giant mouse idea before anyone else can start*
    hopefully ths will turns out pretty good. Is the wood light or heavy?
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    It looks like MDF, so quite heavy.
    Definitely not one to take to a LAN :D
  3. Temo Vryce
    Temo Vryce What's a Dremel?
    19 Mar 2004
    I'm just glad that I was able to give some direction for this project. I'm definately looking for future updates.
  4. ychamp
    ychamp What's a Dremel?
    20 Sep 2005
    they should have it in schools here in the U.S u can use as a dance pad
    lol
  5. ATOG
    ATOG What's a Dremel?
    27 Jan 2006
    itought of the idea and a big mouse wil come
  6. ATOG
    27 Jan 2006
    it is MDF and it is indeed heavy only so nice to work with ther is also some plastic glas in it it is also heavy
    i will post the final weight in the end
  7. ATOG
    27 Jan 2006
    next i need to drill holes in the back of all the 100 keys so the screws could go in ok
    i used a piece of plastic glass to make a mold so i can drill the holes in the same places in all the 100 keys, and the keys could fit perfectly in the mold. i drilled all the 400 holes in the keys.
    this is the mold
    this is a key which i drilled 4 holes in
    you can discuss my project here http://forums.bit-tech.net/showthread.php?p=1165543#post1165543
  8. Dozr
    Dozr What's a Dremel?
    9 Aug 2005
    :jawdrop: awesome idea :rock:
  9. Payne280
    Payne280 What's a Dremel?
    19 Oct 2005
    will be a nice piece for the wall, but I just don't see it as being practical
  10. ATOG
    27 Jan 2006
    it will not be practical it is just for funn
    your not going to type bigg leters on it is just funn on lan partys when you play games on this big keyboard
    and it is supper funn for the little kids when the just learn to use a computer
  11. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    Cool, looks like this will be pretty well done if this is a sign of things to come.
  12. Cabe
    Cabe What's a Dremel?
    14 May 2002
    playing bomberman or worms on this with a projector would rock!
  13. knuck
    knuck Hate your face
    25 Jan 2002
    wich color do you plan to paint it ?
    I think it is indeed a GREAT idea for kids !
  14. ATOG
    27 Jan 2006
    i did not diside yet i think normal colors black and white
    so it looks like a normal keyboard
  15. ATOG
    27 Jan 2006
    next i have made a acrylic plate and put a gideline on to drill holes for the keys
    i use a pice of acrylic again to make a mold and get all the holes in the same spot
    now i only need to drill more than 500 holes in the acrylic plate so the keys can go on
  16. MonkeyTurnip
    MonkeyTurnip What's a Dremel?
    23 Aug 2005
    that is great, cant wait for more updates, you sir are a nutter
  17. saab
    saab What's a Dremel?
    28 Nov 2005
    Haha. Very funny mod !!!
    KUTGW !!!
  18. offroadracer789
    9 Dec 2004
    multiplayer single-player games. 1 person controls wasd and the other uses the mouse.
    that's be some serious fun
  19. Cabe
    14 May 2002
    you'd need a scale mouse, perhapd a bumper car?
  20. HapeMask
    HapeMask What's a Dremel?
    19 Jan 2006
    Ahahahah :D that's exactly what I thought when I saw it. Imagine playing CS and having to rely on both CS AND DDR skills at the same time :)
