G-gnome's Orac³ - Part 2
Discussion in 'Project Logs' started by G-gnome, 1 Sep 2003.
Thread Status:
Not open for further replies.
  1. Da_BaCoN
    Da_BaCoN Minimodder
    25 Aug 2002
    usually on most mods, there's always some little thing that i would change if i was doing it, but so far, everything you've done seems to be perfect! :jawdrop: you've got a simple, yet kick-butt design and you're doing a GREAT job of applying the same look to all parts!
  2. fohkus
    fohkus What's a Dremel?
    12 May 2002
    .............................. :waah:
  3. Goldberg
    Goldberg What's a Dremel?
    27 Aug 2003
    G-gnome, where can I buy this??
    This is what I need for my stealth frontpanel :naughty:
  4. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Big Model and Hobby stores may have it or anywhere that sells stuff for architecture students or model makers. I got mine at a big store that sells radio controlled aircraft, model kitsets, train sets etc. (I think it was called 'Hobbyco'). I don't really hang out in those sorts of shops so can't really remember.
    It's made by "a.m.r.i Architectural Scale Models" code AA614. Maybe google or checking your model shops? It doesn't say on the pack where it's made. I'm sure there must be an equivalent (identical) product in the Netherlands.
    That's all the info I have - hope it helps. Good luck!
  5. FlashPanHunter
    FlashPanHunter What's a Dremel?
    22 Aug 2003
    Outstanding. The only thing more exciting than these pictures is this:
    Oh man :thumb:
  6. Goldberg
    27 Aug 2003
    Thanks, I''l go look for it.
    By the way, this case starts really to get looking like an ORAC, but really up to date an futhoristic.
  7. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    I really like the chrome "rats nest" of wires, and the front looks sweet. :thumb:
  8. jwill
    jwill What's a Dremel?
    2 Oct 2003
    I don't know if you have your computer hardware to go in this all figured out but i have some motherboard suggestions for you to keep with your color theme.
    The revision A of the LanParty NForce2 Ultra series would be a great choice in my opinion. Since the new revision includes the 4 mounting holes around the cpu made for aftermarket cooling applications such as watercooling.
    Here's the link to the revision B on DFI's site.
    I've heard some great things about the revision A and I'm sure the revision B won't let us down.
    Perhaps your thinking of a silver style motherboard instead of black like a silver edition from Soyo. For example the SY-KT600 DRAGON Ultra Platinum. Although I do not recommend Soyo boards.
    I can say this is the best computer setup I've ever seen to date. I only wish i could buy one for myself. I salute you. :dremel:
  9. thorilan
    thorilan What's a Dremel?
    25 Aug 2003
    doh your right. sorry . some of us just get so excited when we see the pics our brain dont function other than to produce saliva ;)
  10. G-gnome
    8 May 2003
    Np Thorilan. Happens to me too sometimes :brrr:
  11. Risky
    Risky Modder
    10 Sep 2001
    FIne, fine work there.
    I' wonder if you are planning a full compliment of PCI cards there. I quite like a 'busy' case.
  12. G-gnome
    8 May 2003
  13. KniFenForK
    KniFenForK Minimodder
    11 Oct 2002
    Dude that is awesome, I dont see why some people are bothered about all the cables, it makes it look a lot better and unique! Well done mate! :thumb:
  14. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    oh well that makes sense.
    chrome looks good no matter what the texture is.
  15. Jordanis3r
    Jordanis3r Jigsaw Master
    8 Jan 2002
    good work - hope the leg gets better soon!
    with regards to mb steathing - have you thought about making a fibreglass hood to encapsulate the topside with cutouts for cpu and nbridge cooling (plus agp slot exposed) then getting the fg hood chromed? - not suree how much of the mb you want to see ... :)
  16. at_b
    at_b What's a Dremel?
    28 Mar 2003
    like he said several times before...the whole mb will be stealthed(can t wait to see that...that, and those cd writer/dvd cables)
    now i really have to look for the movie that inspired this 'rage' in design
    :thumb: :dremel:
  17. JeffPH
    JeffPH What's a Dremel?
    17 Mar 2003
    awesome job Gnome. am speechless and am drooling over your case :)
    GREAT JOB!!!!!!!
    :clap: :clap: :clap:
  18. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    I really like the pattern of the radiator front cover.... Simple and well suited to the overall style!
    You are a genius! :clap:
  19. Carbon
    Carbon Banned
    8 Jan 2003
    it seems a mess of cables right now, BUT i straingly like it :D
    the case & hardware just keeps getting better and better but ive found something that i dont like, its the Eject buttons, ive never liked them on any cd-drives but hey, thats just me :D
    and oh....
  20. fohkus
    12 May 2002
    you know.. i have this huge problem with cutting straight and u seem to do it like nothing w/ a hacksaw?? Is there a particular hacksaw thats better than others or are they just all the same? i was thinking of getting one for myself since it seems to work so well for you! I usually use the jigsaw but if i dont file for 2 hours it'll look like crap :sigh:
Thread Status:
