G-gnome's Orac³ - Part 2
Discussion in 'Project Logs' started by G-gnome, 1 Sep 2003.
Thread Status:
Not open for further replies.
  1. Omnipotence
    Omnipotence What's a Dremel?
    5 Nov 2003
    Well, it did get a few hundred views when I posted the link on the forums :D
  2. HQ08-Modder
    HQ08-Modder What's a Dremel?
    14 Nov 2003
    AAhh bugger now i want to chrome things. Are the hard drives chromed?
  3. contained
    contained What's a Dremel?
    18 Nov 2003
    All i can is OMG.
    I read all 4 updates from the beginning since last night and finished reading it now.
    You seriously have got some mad skillz!
    Man, now you got me excited to see how the finished work will look. Definitely can't wait to see how you stealth that mobo. I'm trying to imagine it now, got some kinda idea... can't wait to see the next update see if im right :D hehe
    This is like readin a novel or trilogy or something hehe. Definitely gotta give you props for your work and time you spend updating us on these logs :thumb: :dremel:
  4. dragon2
    dragon2 What's a Dremel?
    17 Nov 2003
    Please reply......
    G-Gnome, I see your job, i send you two e-mail but.... nothing.
    Please reply me. Your plexyglass cut is laser cut or not???
    I'm italian my english is bad. :sigh: :sigh:
    The cut of plexyglass green in te corner and holes is a laser cut???
    Please reply to my answer.
    Very good job.
    hi :clap: :clap: :clap:
  5. fohkus
    fohkus What's a Dremel?
    12 May 2002
    laser cut? u should read part 1 of the log i'm sure you'll find a answer right away.......... unless im not understanding your question correctly
  6. dragon2
    17 Nov 2003
    fohkus (and others) please i'm not english, reply.
    G-gnome use laser cut or not.
    For example in this image http://bit-tech.net/images/g-gnome/ud1.jpg how cut the plexy so perfecly.
    I don't read total forum i don't undestand it.
    Please write where i find how cut plexy green.
    Thank You
  7. fohkus
    12 May 2002
    hack-saw.
    sand paper.
    file.
    :D
    no laser cutting was used.
    you can just look at the pictures and you can see how he did it, u dont have to read it if u dont understand it :)
  8. dragon2
    17 Nov 2003
    Now i understand thank you.
    very good
  9. at_b
    at_b What's a Dremel?
    28 Mar 2003
    no
    just stripped off and polished...
    it actually says at the begining of the update...
    :nono:
  10. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Re: Please reply......
    Very sorry dragon2, my email has been down the last day or so. I sent a reply but it looks like fohkus has answered your question anyway.
    Definitely no laser cutting.
    (dragon2 needed to answer a debate going on in an italian forum regarding the cutting of my plexi).
  11. Jack
    Jack Minimodder
    22 Dec 2002
    well done G-gnome!!!
    One thing has shocked me! and thats the Danger den W/B's ?
    I didnt think you'd use that style dont ask me why but i had other W/B's on the brain for your case!
    Jack
    ps im guessing the hdd rack cant be removed while the watercooling is in there
  12. PTK
    PTK What's a Dremel?
    3 Nov 2003
    Re: Re: Please reply......
    Well guessing its watercutting then :duh: since you get better result and havent seen any signs of you going for second rate here before :rock: :rock:.
    PTK
  13. at_b
    28 Mar 2003
    u ppl don t like to read do you...
    he cut them manually
    well...with the tools he had
  14. PTK
    3 Nov 2003
    Sorry, usually look at these @ work. So dont have "time" to read all the texts, only the parts that im interested in... close to 1000 posts in this thread you know ;).
    :dremel: on.
    PTK
  15. G-gnome
    8 May 2003
    Re: Re: Re: Please reply......
    All the cutting and shaping of plexi in the mod was done using one or more of the following (starting with the most commonly used items):
    Hacksaw (most of the work)
    Files
    Sandpaper and sanding block
    Plexi-drills
    Holesaws
    Dremel cutting wheel
    Router (used twice on cutting the case holes)
    Bandsaw (used on only a couple of pieces before the blade broke)
    Disk Sander (used once on the HDD rack mounting blocks)
    That's about it.
    I'm flattered folks think it looks laser or water cut :)
    Even if you don't want to read the text, there are plenty of pictures in the logs themselves showing my cutting and shaping.
  16. djengiz
    djengiz Pointless.
    16 Aug 2002
    Dear G-gnome,
    I really love your work. But I have a question that is not directly related to your masterpiece. Is it correct that you have written software to edit your projectlog?
  17. piloux
    piloux What's a Dremel?
    12 Nov 2003
    G-gnome , can I ask you which type of digital camera you has used to take all these very nices pictures? excuse me if that question has already been asked
  18. Jonas79
    Jonas79 What's a Dremel?
    13 Nov 2003
    He's using a Sony Mavica MVC-CD500 5.0 Megapixel. Has been asked before ;)
  19. piloux
    12 Nov 2003
    thank you for that quick reply :) and sorry asking that again
  20. Bugaloo
    Bugaloo What's a Dremel?
    27 Sep 2003
    The way you attached the nb cooler, :idea: pure genious. I`m doing the same with mine. Keep up the exelent work guy. :dremel:
Thread Status:
