News G.Skill announces Trident Z5 DDR5-6600 32GB memory kits
Discussion in 'Article Discussion' started by bit-tech, 21 Oct 2021.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. monty-pup
    monty-pup Minimodder
    8 Apr 2018
    Ok. I need educating. Those timings are awful, right? But the speed 6600 is great, right? Is there a definitive guide to what’s good and what’s not? RAM is quite confusing!
    Also I was reading that my 5950X didn’t like anything over 3600 … is that right?
  3. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    I've been wondering this. Is DDR5 c36 compared to DDR3 c9 (3x speed, but 4x latency) better for everything, or mainly certain things and by how much in real-world usage terms, not just theoretical possible max bandwidth?
    I assume the answer is "everything" but would be interested to know what the effect of the different ratings is and how they stack.
  4. wyx087
    wyx087 Multimodder
    15 Aug 2007
    I *THINK* this is how it works DDR4 3200 MT/s CL16 = DDR5 6400 MT/s CL32.
    But at double transfer rate, even though you find data in similar amount of time, you can stream twice amount of data within the same time frame.
    So despite double transfer rate, overall gain is less than double, it will depend on architecture optimisations.
Tags: Add Tags
