Hardware G.Skill Falcon 128GB Review
Discussion in 'Article Discussion' started by Guest-16, 24 Jun 2009.
  1. Guest-16
    Guest-16 Guest
  2. samkiller42
    25 Apr 2006
  3. wyx087
    15 Aug 2007
    a SSD related question: how do i review the level of wear it is getting? i keep hearing people say "my daily wear is ___ and by that rate, my drive will fail in 2020"
    also, can my Samsung SSD use that wipe.exe? or is it manufacturer specific like the overclocking tool by EVGA
  4. trig
    trig god's little mistake
    10 Aug 2006
    about $3/GB...when it hits around $1.50, i might be interested personally.
  5. capnPedro
    11 Apr 2007
    No, it really isn't. Unfortunately! My idea of "affordable" is £0.75 per GB (still 10 times more expensive than HDDs, mind).
  6. Combatus
    16 Feb 2009
    The EVGA Precision overclocking tool works on non EVGA graphics cards too ;)
  7. Guest-16
    Guest-16 Guest
    Then you're not in the SSD market :p You can't want a Core i7 and only intend to pay for an E5200..
  8. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Do us all a favour.
    Get one of these SSDs, and get a standard mechanical disk. Build two otherwise-identical systems and put XP on them. Set things up so that they continuously reboot and reload XP.
    Let them do this until both drives have failed, which will probably take about a year for the mech and considerably less for the flash, and then tell us what you get.
    P
  9. wyx087
    15 Aug 2007
    indeed.
    i think some people are spoiled by HDD's low prices. i remember the days when a 2GB disk costs the same as 2TB disks. and that's less than 15 years ago.
    if you want speed faster than any HDD, including Raptor, you'd have to pay for it. after switching from a Raptor, the quietness of it is amazing.
    the issue of failing is only a real issue when you are a stupid user and don't apply the tweaks. move ProgramData and Users folder off C drive onto a fast application drive such as WD Black, and then disable as much logging on C as possible. and now the SSD will be both fast and reliable.
  10. capnPedro
    11 Apr 2007
    You're very right. But it's not like SSDs are offering 10 times the performance of HDDs (random access times given, however).
    28 times the price, for double the performance, and this is afordable? I don't think I want to be in the SSD market just yet, thanks.
  11. wyx087
    15 Aug 2007
    SSDs should only be compared to the WD Raptor or velociRaptor series, all other hard drives are dead slow and useless for OS drives.
    compare 64GB Samsung on Novatech for £87 against their £55 74GB WD Raptor. i'd say the SSD is a much better buy at those prices.
    -0.74 £/GB on Raptor
    -1.36 £/GB on Samsung
    came from Raptor, the Raptor is loud and not as fast as the SSD, only good point is that it's very, very reliable when you don't plan to move your computer. SSD on the other hand is ultra reliable when you are moving your rig, but most importantly everything feels instant and you don't feel the program is being launched from the disk, it feels as though it came from RAM because the lack of drive seaking.
    for double the price, you get almost double the performance.
  12. naokaji
    naokaji whatever
    8 Dec 2006
    Or more if you look at the Iometer random combined r+w results (which in my opinion is the one that represents the felt performance gain the best).
    Anyway, lower prices and higher capacity would still be nice, but do I regret buying a SSD at the current prices? not one bit.
  13. hodgy100
    hodgy100 Minimodder
    2 Jun 2008
    I wish they would bring out a 32GB version of this, just so that I can use it as an OS drive :(
  14. Guest-16
    Guest-16 Guest
    What's XP?
  15. Guest-16
    Guest-16 Guest
    Look at graphics upgrades then - twice the performance for x the price if we look between generations?
    You're also looking at total capacity too - you dont buy a 1TB drive for your OS then fill it all! Nor do you with and SSD. You cant compare mass storage with performance storage.
  16. Baz
    Baz I work for Corsair
    13 Jan 2005
    Tough to measure SSD wearing. I'll be hopefully doing some research into SSD wearing and performance degradation soon to clear some of this up.
    Sadly wiper.exe is specific to the particular manufactuerers drives, (or rather who the drive thinks manufactuered it ;) ). Sasmung has yet to release such an application i'm affaid.
  17. Baz
    13 Jan 2005
    Because we all use an 8 year old OS rebooting thousands of times a day with a £300 performance part designed for modern operating systems? I think we should also throw in some Windows 98, 95 and even 3.1 testing too just for people to see the improvement an SSD will bring to that '96 Packard Bell.
  18. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    BEST OS EVOR!1!!111
    Still think these SSD drives are daft price wise :X
  19. phuzz
    phuzz This is a title
    28 May 2004
    last page, 4th paragraph
    should be
    Oh, and you so should install win95 on an SSD just to see what happens...
  20. capnPedro
    11 Apr 2007
    OK I see what you mean now. I've never looked at it that way I guess because I've never had performance storage and mass storage! At the moment, I have my OS on a partition on a 1TB Barracuda 7200.11.
    Next upgrade (after uni :( ) will have an SSD, definately, and probably a couple of 5TB drives in RAID. :lol:
Tags: Add Tags
