G Skill HZ/ Cell shock
Discussion in 'Hardware' started by Pie_uk, 5 Jan 2007.
  1. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Haven't played with dividers on the P5B so can't really comment as to how well memory overclocks. Seem to recall some issues with certain dividers over 400 FSB though. Can't remeber which ones - will try and dig em out for you.
    The fact that the Cellshock PCB can cope with more voltage is great, but you're still limited by the chips themselves. Much over 2.4v 24/7 through D9 and you risk it degrading over a period of time. Might allow for more stable voltage to the chips meaning they might clock a bit better at the same voltage but thats probably all you'll gain. Thats not to say don't get the Cellshock, it looks to be spiffy memory but consider what you'll be using it for. Does it offer you anything extra over some cheaper D9 based IC's? If it does then its the ram to go for.
    <edit> Also remeber PIE the NBCC issues from running < default multi. Should be ok depending on how far you drop the multi but its something to be aware of. 500 FSB from a 6600 isn't air territory, you'll probably be running ~ 430 MAX under water </edit>
  2. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    NBCC?
    i cant decide if its worth going with the 8000 stuff or not. i have emailed tekheads 3 times now lol
  3. Highland3r
    25 Jul 2003
    Click me
    Further info available in the techrepository link in the first post :)
  4. Pie_uk
    6 Apr 2005
    cheers for that, i shall have a good read through
  5. Supershanks
    Supershanks What's a Dremel?
    14 Mar 2005
    It's up 2 you the 6400 should scale up but will usually be short of 8000 5-5-5-5. But from what i've seen all the cellshock are pretty well respected.
    as WhiskeyAlpha says the specs are good including the 8 layer pcb . Don't think u can go wrong with any just get the set your comfortable with.
    btw where did u catch your XEON 3060 ??
  6. Pie_uk
    6 Apr 2005
    yeah i will go with the 6400 set. if I need more from the mem i shall sell up and go with the 8000 set.
    ah yes my lovely xeon 3060, cant wait to clock that up.
    the etailer i got it from no longer sell them ! i doubt you can get one in the UK now . not that i have looked since getting this.
    a mate found 2 and he told me to call them up and buy it asap
  7. Supershanks
    14 Mar 2005
    Yes cpu is last thing i have to buy, will have to wait till 15th unless wife feels sorry 4 me. will get a 6600 but like the looks of the Xeon 3060 :thumb:
    Luck with the 6400 :D
  8. Pie_uk
    6 Apr 2005
    yeah if you can get a 3060 go for it. i got one because its different !
  9. Pie_uk
    6 Apr 2005
    right lads i went for the cellshock memory pc2 8000 c5
    :D happy now
  10. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    Have you received it yet or do you mean just ordered it?
    I'd be very interested to see how these perform.
  11. Pie_uk
    6 Apr 2005
    ordered sorry. i am awaiting my p5b deluxe to. i shall let you know whats what when it all arrives. i will also need a hand overclocking
  12. Guest-23315
    Guest-23315 Guest
    those Cellshock moduals seem to be doing good things over on XS....
    have fun with them :D
  13. Supershanks
    14 Mar 2005
    Well went commando today just installing programmes on raid install. Very smooth build no issues. :D
  14. Pie_uk
    6 Apr 2005
    cheers mankz yeah i guess they use some good D9 chips :) cant wait
  15. WeldZilla
    WeldZilla What's a Dremel?
    22 Apr 2004
    I will watch for your results guys. I can't predict what you will get in the way of performance as I have not tried anything but G.Skill. Post up your results and let us know
    WZ
