So, I bought an arduino-based smart plant care kit a while back, and I'm only now just getting around to putting it together, but I've run in to a wall of my own ignorance regarding...uhhh...water pumping standards(?). The water flow sensor was apparently G1/4, but the G1/4 tubing doesn't fit...it does, however fit the pump perfectly. I measured everything with calipers and the measurements are below. My question is do you think this along with this would fix it? Or am I being an idiot and missing something obvious?
that would work or look for a fem 1/4 barb you might also wont to put some ptfe or LOCTITE 55 on the threads
