g15 keybaord keys
Discussion in 'Tech Support' started by morallo, 15 Jan 2008.
  1. morallo
    morallo What's a Dremel?
    25 Dec 2007
    ok when i got my g15 keybaord, the newest version, some keys dint work but then they startyed working, i dont know if i did somthing or what but they have stoped working, does any 1 know why
  2. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    I'm not sure, a few people have said they had problems and it was some switch or lock on the keyboard, i myself own the first generation (old flip up lcd, blue LED one) and i never had any problems. If you can't figure out the problem, just RMA it.
  3. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    That would be my advice too.
    You've received a faulty product - such that it "isn't fit for the purpose it was intended".
    Your'e perfectly entitled, therefore, to request a replacement... at no additional cost to yourself :idea:
    That said... you may be asked to pay for the return postage?
    But you should be refunded those postage costs, after they've tested the keyboard.
  4. morallo
    25 Dec 2007
    ok thx, ill send it back soon as possible, but i dont now why it did this befor and started working, thx anyways
  5. Fishlock
    Fishlock .o0o.
    22 Nov 2004
  6. morallo
    25 Dec 2007
    tried the update but nothing still, ill have to just take it back
