Case Mod - In Progress G5 Sacrilege update Jun. 15th a tale of two doors
Discussion in 'Project Logs' started by jhanlon303, 14 Feb 2008.
  1. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    It is quite warm here today, it's around 22C or so for the rest of you. ;) Gotta love the Rockies! Shirt sleeve weather in the city and great skiing a couple hours away in the mountains.
    I see what you're getting at with the aluminum shell, John. Alas, you don't have a shrink ray to just take a G5 case down to size. It is rather a puzzle, but coming along quite nicely.
  2. jhanlon303
    7 Sep 2006
    It's a quandary to me also. I'm sitting here with my friends from Ireland - the 4 Guinness Brothers. I have the Apple wrap around measured and taped up for cutting. We are discussing "tips, tricks, tools and techniques"! It's a big step to cut the wrap around, door on one side, door on both sides? Needs some thinking.
    While I was out to the store with my wife for groceries, I found a new treasure! Check out the Modding section for:
    http://forums.bit-tech.net/showthread.php?t=147923
    $2 Thrift Store Treasure. Probably should change the name to "$2 Cooler Master"
    John -
  3. InferiorPlanets
    InferiorPlanets Worshiping the SilverStonehengeā„¢
    22 Jan 2008
    LOL, Tell them I said hi...and then kill a couple of em for me :thumb: (I'd kill for a good Guinness on tap here...well minus the $18 a pint pricetag)
    Congrats on your newest MOTM nomination Bro!
  4. jhanlon303
    7 Sep 2006
    Patch Panels and J. B. Weld
    My team and I discussed cutting the wrap around until late last evening. We decided the look was there but we needed to get the cage ready. See post #162. So ...
    I took the cage all apart, squared up the front cut on the grinder, and cut the patch panels 6 rows high to reinforce the horizontal cut on the front.
    I'm going to show you only one of the seams in progress because I don't want anyone falling asleep.
    The patch panel from the front:
    The 3 mm holes all lined up and ready to go.
    From the back side with the long bolts showing:
    The J. B. Weld mixed up on a chunk of plexi from the closet and applied to the front of the cage piece.
    2 back joints with the mesh, the top seam using a piece of the original bottom in the inside, the bottom with a piece inside takes care of the outer welding. When it all dries, all the mesh gets another coat from the inside.
    Just thought a quick one would do since Cyprio covered this in enough detail to teach me how.
    Oh by the way 74 degrees yesterday, blizzard conditions and white outs to. We lost 50 degrees since yesterday!!!
    John
  5. godmonkey
    godmonkey What's a Dremel?
    14 Jan 2007
    I thought it was the other way around! :nono:
    I would try the plexi on the inside of the curve idea. Use the inner part that curve as your template for the alu. Might work out the size difference. Of course I could (and prob am) horribly wrong about that. Hard to say with out actually see this in the real world.
    About to get the same weather thing here in Missouri. In the 70's today chance of snow tomorrow night :sigh: But that is the norm here. Don't like the weather just wait 10 minutes might get better (or usually worse)!
  6. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    I actually thought that you would apply the JB Weld direct to the
    back patch stripe and then fasten it with the screws on the inside.
    When that has cured then use the JB Weld to fill the crack on
    the outside ............
    Alan
  7. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    I just love those meshes on the mac G5. Interesting idea.
    Subscribed
  8. jhanlon303
    7 Sep 2006
    Trying both techniques as I want to get the best hold with the goop. Hard to put the weld stuff on and then get the bolts tightened afterwards. Messy stuff! Need more hands or figure out a better technique.:sigh:
    John
  9. Nix
    Nix What's a Dremel?
    22 Nov 2005
    How easy was it to bend the aluminium. Its one of the parts im most worried about with my mod, once i got the time to cut it out and all that jazz.
    Motm for me.
  10. jhanlon303
    7 Sep 2006
    Actually if you skim through the earlier posts you will see that I didn't bend any of the original aluminum parts. I measured and tested and measured ... and cut the G5 pieces down to this size. I once thought of bending but the slots and grooves in the sides for other pieces put me off that idea. These pictures are all original Apple bends.
    Thanks for the question and for looking.
    John
  11. jhanlon303
    7 Sep 2006
    Technique #2
    For Cyprio and Alan
    There has been some discussion about using the J. B. Weld from the back on the patch panels. This is technique #2 for me to use the goop from the back. Here goes. I'm posting before I actually do this and get dirty.
    Picture #1
    While hanging my shirts, I found some wire coat hangers. I cut some chunks and bent them into this U shape after determining hole spacing.
    Picture #2
    This shows the pins inserted into the patch panel from the inside. They are long enough to allow room to apply the J. B. Weld and give me a nice handle from the other side.
    Picture #3
    Pulling the pins tight from the front after spreading the J. B. Weld on the patch panel pulls everything in to allignment.
    Picture #4
    Get the bolts ready and insert them from the front, slap on the nuts, and tighten up. That didn't sound right!
    Pull the pins out and just the bolts hold it together. Remember the patch panels are made of the same hole spacing since they are cut from an original Apple frame.
    Want to discuss or just let me crash and burn here?:confused:
    John
  12. hanabusa
    hanabusa What's a Dremel?
    17 Feb 2008
    It is good.
    It has come into view.
    I look forward to completion.
  13. jhanlon303
    7 Sep 2006
    Thank you. I have seen your work. It is very good.
    John
  14. jhanlon303
    7 Sep 2006
    50 page hits and no responses
    OK. Nobody cares but I did it my way.
    From the outside:
    You can't see it too good at this resolution but the weld epoxy is oozing out the front! Yeah.
    From the inside :
    Slathered some more in here and forced it down into the mesh with a throwaway plastic knife.
    Totaled my little work bench but it has white removable shelf liner on it. Now the question is whether I can get the grey goo off my hands from the holding and screwing before I have to go to my $1 a minute take home job in the morning. I'm thinking acetone or maybe napalm.
    Don't tell my wife Marilyn but I got some on my wedding ring.:sigh: Had that bugger since 1980. Ring cleaning first, hands next.
    Peace.
    John
  15. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    and as always, i'm too late ;/ John from the very beggining i was sceptic about that glue :/ it won't hold at hands becose of sweat but ring can be tricky :/ I hope it will come off easy.
    If this case won't be stiff enough this epoxy won't hold :/ i was experimenting with epoxy resin and fibreglass which is very flexible... alu is hard to bond ... but this i special glue so should be good.. I will keep my fingrs crossed
    Greatzzz
    Tomek
  16. jhanlon303
    7 Sep 2006
    Thanks Tomek.
    /Off topic I started my new project with your countrymen from Z.G. today. Looks really interesting. /end Off topic
    I hope this works too! But never fear I have 2 more G5 cases. :D We will get this done.
    Quote for today:
    "Never have so few worked so hard for such little results"
    From me
    John
  17. theAlien
    20 Aug 2007
    John ...... I do care ......... you just caught me sleeping :D
    We are in different time zones ......... like 7 or 8 hours difference.........
    Good idea your way ......... hope it works
    Alan
  18. jhanlon303
    7 Sep 2006
    Sorry to wake you:hehe: I just got the idea and wanted to share. It worked well aside from being messy. Everyone else has their cases coming together and mine was still in pieces so I put the pieces together.
    The front joint hardened enough that I could take one of the bolts out to see. It wouldn't pull out but the epoxy is hard enough that the bolt could be unscrewed - made its own threads. Nice stuff. And with almost no weight this case should be sturdy enough for my nightstand or my cube at work?
    Sleep is over rated.
    Robby - "I rarely use it. It promotes rust"
    John
  19. theAlien
    20 Aug 2007
    I'm sure if JB Weld ,if mixed and cured properly,will hold most parts together
    forever.
    I like to use it and it has worked well.
    Hope to see the parts sanded down and re-drilled soon.
    Oh.....and sometimes I do fall asleep even if I don't want to. :hehe:
    Alan
  20. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Man, I do not envy you regarding this bonding problem! :hehe: JB Weld sucks on so many levels, but it's a necessary evil sometimes.
    @Alien: Narcolepsy Cheesecake!
