Hardware G80: NVIDIA GeForce 8800 GTX
Discussion in 'Article Discussion' started by Tim S, 8 Nov 2006.
  1. Kevin_G
    Kevin_G New Member
    9 Nov 2006
    The NVIO chip could be doing quite a number of things. It looks to be handling HDCP for the dual link DVI connectors and SLI connectivity (the traces for the SLI connectors appear to run into this chip) besides RAMDAC functionality. The chip may have a digital audio pass through functionality for HDMI connectors. There is a spot at the end of the board where a 6 pin header can be soldered on, this could easy be for digital audio in for HDMI (or many other things).
    Replacing this chip alone could easily add video in/out and audio functionality to the card without having to redesign the entire GPU. There are two other digital display technologies on the horizon - Unified Display Interface and Display Port. Having an external chip control what connector is used allows for a bit of flexibility instead of wasting precious silicon space on the GPU itself to support all the various display technologies. By having an external chip for display out put should also for the main GPU to clock higher by not having to deal with as much noisy analog circuitry on chip.
    The downside to the NVIO is the additional cost of another chip and a more complex board layout. The GF 8800GTX board layout is insanely complex with a 384 bit wide memory bus anyway so that is pretty much a null point.
  2. neocleous
    neocleous Member
    12 Feb 2002
    I have a question how loud is this card I couldnt find anything in the articale but I might have missed it.
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Found on page 1. :)
  4. neocleous
    neocleous Member
    12 Feb 2002
    Ah stupid me thanks
  5. mgemmons
    mgemmons New Member
    30 Nov 2006
    BF2142 @ 1920x1200?
    I notice that the Battlefield 2142 (BF2142) test show it running at 1920x1280, how did they do that? AFAIK, 1600x1200 is the maximum resolution allowed. Trying to force 1920x1200 does not work as a command line option as it did in BF2. :confused:
  6. Tim S
    Tim S OG
    8 Nov 2001
    Hi and welcome to the forums. :)
    We used the widescreen hack described on widescreengamingforum - it doesn't enable "true" widescreen because it doesn't change the field of view, but it does allow you to run the game at your screen's native resolution: http://www.widescreengamingforum.com/forum/viewtopic.php?t=6240
    Hope this helps
    Tim
Tags: Add Tags
