Hardware G92: Nvidia GeForce 8800 GT
Discussion in 'Article Discussion' started by Tim S, 2 Nov 2007.
  1. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    Got my 8800 GT today, just tried Crysis and Bioshock quickly and it ran both fine with everything on high @ 1680x1050 (no AA). Well chuffed so far :D (need to test Crysis a bit more)
    Best £150 i've spent on my pc in a while :)
  2. Tim S
    Tim S OG
    8 Nov 2001
    Good to hear, glad you like it!
  3. Tim S
    Tim S OG
    8 Nov 2001
    The latest drivers unfortunately break the current version of Rivatuner and you cannot use it for overclocking, only for detecting clockspeeds using the monitoring tool. I love Rivatuner and use it almost exclusively for clock setting, overclocking and monitoring clock activity.
    We've not done any overclocking with the reference cards, but we have a bunch of retail cards in that we will be overclocking. This was merely an architectural review, meaning we compared everything at stock speeds. For the roundup (if that's what it ends up being), I won't be testing as many games as I'll be looking more at percentage increases over the reference card, but if there's time I can add in a 8800 GTS 640 at 550 without a problem...
  4. sandys
    sandys Multimodder
    26 Mar 2006
    Rivatuner 2.06 works fine as does Ntune, but with ntune you can't change the shaders clocks and mine crap out Not much after 1800.
  5. Tim S
    Tim S OG
    8 Nov 2001
    Yep, that's only been released since finishing the review - I believe 2.06 was either released yesterday or the day before.
  6. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    So typical,
    ordered a gecube radeon 2900xt 512mb that will arive tomorrow. Then I saw this. 33% cheaper than my 2900xt and quite a different in performance, thats my usual luck. And ordering the 2900 not long before the release of 3800 cards, could I have picked a worse time?
    Well It seems I will have to try to send it back and buy this instead.
    /GNU
  7. Guest-23315
    Guest-23315 Guest
    Can anyone please tell me how loud this card is in real life?
    Also, is it a whiney fan, or a deep loud fan please!
  8. Tim S
    Tim S OG
    8 Nov 2001
    What card do you currently have?
Tags: Add Tags
