GA-7N400 Pro2 Rev.2 Won't Allow Full Speed Proc
Discussion in 'Hardware' started by BvBart, 27 Aug 2004.
  1. BvBart
    BvBart What's a Dremel?
    29 Jul 2004
    If anyone has ever seen a 7N400 Pro 2 Revision 2 board from Gigabyte, they'll know that it has these infinitly retarted little dipswitches for setting CPU multiplier, as well as Clock Speed, sort of.
    My problem is that my Barton 2500+ is being read by my BIOS, computer, CPU-Z and anything else I throw at it as an Athlon XP 1100Mhz chip. The most I can figure is WHY this is happening, but I can't figure how to fix it.
    Since it's a post week-39 superlocked 2500+, I know I've gotta set the multiplier on the dipswitches to x11.0, which I have done fine. However, the Clock Speed switch has two settings, and it looks like this:
    Code:
     _____
    | O_N |
    | |X| |
    Now, the ON setting represents Auto FSB detection, or having the BIOS recognize your manual input in-BIOS, while OFF sets it to 100Mhz, period.
    The detection as 1100Mhz comes from having it set OFF, with the 11x multi. The obvious answer would be to switch the Clock Switch on, but when I do that, I can POST, but the computer boots down in a few seconds, with five beeps. The AMI BIOS guide tells me that means a Processor error, but that doesn't make sense, as the 2500+ is designed to be able to run at higher than 100Mhz.
    While set to OFF, no matter what is input into the BIOS, the designation doesn't change. Anyone have thoughts?
  2. Go4t
    Go4t i
    13 Dec 2003
    i have a gigabyte too and there should be an auto setting for the multiplier
    but i dont know what to tell you about the other dip switch as mine has two for fsb settings
  3. BvBart
    29 Jul 2004
    Yea, that's the problem, when I set it to Auto, it dies with beeping signaling a processor error, confusing the hell out of me.
  4. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    i use the same mobo, have u tried reseting the bios? try that and if that dont work give the thing a bios flash and if that fails call the place u got the bpard from
    aslo wat ram and bios revision r u using?
