GA-X58A-UD3R Intel Socket 1366 + 6GB Patriot Viper DDR3
Discussion in 'Gigabyte' started by trimbal, 13 Apr 2010.
  1. trimbal
    trimbal New Member
    13 Apr 2010
    here's my setup for now GA-X58A-UD3R Intel Socket 1366, Patriot Extreme Performance Viper Series DDR3 6GB (3 x 2GB) PC3-12800 Low Latency, Intel i7 930 and XFX HD 5770 XXX 875Mhz 1GB Edition. http://www.ebuyer.com/product/190734
    would that all work? and would the ram run in triple channel @ 1600Mhz or higher?
    What you think? and how much power supply would i need minimum?
    Many thanks for those who help and reply back to me.
  2. bulldogjeff
    2 Mar 2010
    you should put this post in tech help, you'll get loads more replies:thumb:
  3. Delta Nine IT
    Delta Nine IT New to this but not to Modding!
    9 Jul 2010
    That will be a nice build and i would opt for a good quality 650watt PSU as a minimum, i always use something higher than required on a build and would probably opt for a 750w 80+ efficient PSU.
  4. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    I just had a brain-rotting series of problems with that motherboard and as such it's rather difficult to recommend it. I've used Gigabyte quite frequently in the past without any issues beyond the mundane, but there's something about that board and compatibility with SATA drives. Nice spec otherwise.
  5. uz1_l0v3r
    uz1_l0v3r New Member
    22 Sep 2009
    What problems have you had? I've had mine for a year and my pc keeps rebooting at random intervals. Clearly it could be some other cause, but I've narrowed it down to the mobo, cpu and PSU.
  6. Ljs
    Ljs Well-Known Member
    4 Sep 2009
    Yeah no kidding - Moderators last activity was almost a year ago!
    *Edit*
    Just realised this was a necro :(
