Graphics Gainward GeForce 7800GS+ 512MB DDR3 AGP Dual DVI TV Out
Discussion in 'Hardware' started by Minglemouse, 1 Jun 2006.
  1. Minglemouse
    Minglemouse What's a Dremel?
    1 Jun 2006
    does anyone have this card? if ya do would you recommend it?
    thinking of getting it but just need to make sure i would be making the right choice befor spending so much money. :confused:
  2. atanum141
    22 Jul 2004
    no point spending sooo much money on a cripple card on a dead platform....
    EDIT: P.S.....Welcome to Bit-tech.
  3. thestig198
    thestig198 Artificially Intelligent
    24 Jan 2004
    Agree, if you spent that money on a PCI-E card you would get a lot more performance.
    I would hold off until you can upgrade to a PCI-E platform.
  4. Minglemouse
    1 Jun 2006
    What would you recommend for best gaming performance?
  5. Minglemouse
    1 Jun 2006
    i see. one big error when i built my computer last year. i know it and regret it now. thought that would be the answer anyway. :wallbash:
  6. atanum141
    22 Jul 2004
    Personally the best bet is to go and get a secondhand 6800Gt based card....its fast enough for current games and also clocks past Ultra speeds.
    Or u can wait for the AGP version of the 7600 series...but it maybe a while.
    Personally i have a Gainward 6800GT @ Ultra..and it does the job brilliantly. usually can be had for £100.
  7. Minglemouse
    1 Jun 2006
    cheeres. i'll look into it abit more see what i can come up with.
    I currently have the sapphire technology ati radeon 9800 pro atlantis 128MB but i find it lags on many top end games so i have to resort to lowering graphics levels which i hate to do. rater play the games at their full potential.
  8. atanum141
    22 Jul 2004
    i had that before i upgraded, its a HUGE difference and worth the money.Everythig is on high and with all eye candy switched on....espically with the newer games.
  9. thestig198
    24 Jan 2004
    Minglemouse what is the rest of your system like? If you have 512MB or less of RAM then an upgrading that might help a bit. Also you need to consider if your PSU could take a video card upgrade or if you would need to upgrade that aswell.
  10. Minglemouse
    1 Jun 2006
    I have
    Gigabyte K8NS Ultra-939 Motherboard
    AMD Athlon 3500+ Processor
    160GB Hard drive
    2GB Memory
    Thermaltake 450W PSU
    ATI Radeon 9800 Pro Atlantis
  11. Minglemouse
    1 Jun 2006
    all in a Thermaltake Tsunami Dream Case
  12. atanum141
    22 Jul 2004
    Matey just a tip u can use the EDIT buttion to EDIT ur posts if u need to add anything.
    Well what i was gonna say is that if you were thinking of spending that much on the 7800GS u might aswell upgrade to PCI-e system, u have the mem,cpu avail...why not?
    Decent mobo's are avail at minimal cost and a good new gfx card are esay to find for a PCI-e syatem, it prob works out cheaper and also u have the added ability to upgrade down the line.
  13. Guest-23315
    Guest-23315 Guest
    you can spend £40 for a pretty god Biostar mATX mobo with some OCing...
    then with the money left over from not buying the Leadtec, you can get a 7900 GT, which will make everything fly...
    or spend more on the modo and get a 7600GT...
    its that simple..
    AJ.
    PS- welcome to the forums..
  14. Mr.ME
    Mr.ME Minimodder
    22 Jan 2006
    there out
    http://www.hkepc.com/hwdb/gf7600gsagp-1.htm
    specs @ the bottom and benchmarks on next page
    the only question is when wil they be available in stores.
  15. Minglemouse
    1 Jun 2006
    well thatnks for the tips guys. i will most probably go for the whole change to pci-e. might as well do it now rather than get a new graphics card for the agp system then go and change like next year.
  16. Minglemouse
    1 Jun 2006
    As I am now looking for a new motherboard. Does anyone have any recommendations for good performance atx boards had a look at Gigabyte S939 nForce4 2XPCI-E ATX goes not seem bad but if anyone has any different boards in mind, i would be more than welcome to know. cheers
