Hardware Galaxy GeForce GTS 250 1GB review
Discussion in 'Article Discussion' started by Sifter3000, 26 Aug 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    I think you may have your overclocking graph labels the wrong way round...
  3. Claave
    Claave You Rebel scum
    29 Nov 2008
    Who proofed those graphs? Thanks for the heads-up, I'll fix them now.
  4. Tyrmot
    Tyrmot What's a Dremel?
    12 Mar 2008
    I wager 5 quatloos on the newcomer
  5. KRyptonKR
    KRyptonKR What's a Dremel?
    20 Dec 2008
    "Nvidia GeForce GTS 250 512MB – operating at 7383/1,836/2,200MHz using Forceware 185.68"
    core - 7383 MHz NICE :)
  6. I-E-D
    I-E-D Minimodder
    28 May 2009
    Nice review. PIty the extra memory doesn't make too much of a difference.
  7. Veles
    Veles DUR HUR
    18 Nov 2005
    Hmmm, not quite sure now if I should go for the stock GTS 250 or go for the 4870
  8. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    can bit please review the palit gts-250 1gGB so we can compare plz.
  9. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    gladiator battles would be so cool...
  10. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Are those US/UK prices right? It's actually going to be cheaper here based on the current exchange rates.
  11. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    ANY GPU card that offers 1xDVI and 1xVGA instead of 2xDVI with VGA converters for those who need them gets a bit FAT 'No, NO!...' from me without even looking at the specs/results.
  12. tejas
    tejas What's a Dremel?
    30 Sep 2008
    Sorry to nitpick but didn't Harry already review the GTS250 1GB??
  13. Elton
    23 Jan 2009
    This is a different one, same core esentially, but made by a different manufacturer.
    You could say the same for all those 8800GTS/8800GTX reviews that I saw a few years ago.
  14. mascotzel
    mascotzel What's a Dremel?
    2 Feb 2008
    you have OC section,but without actual OC numbers there
    also,Nvidia's requirements for GTS250 are 1.100 memory speed
    Galaxy doesn't even follow that,so as far for memory speed goes,it's an underclocked version compared to the reference one
    the OC numbers don't impress me either,I get bether numbers fron the older first in the line 8800GTS ( from which later derrived 9800GTX,9800GTX+ and GTS250 with/without sloght modifications)
  15. mascotzel
    2 Feb 2008
    ambient temperature is what?
  16. aussiebear
    aussiebear What's a Dremel?
    13 Nov 2008
    The reason provided with the Folding@Home performance isn't quite right. In fact, the author needs to explore this issue in a future article. (Does Folding@Home benefit with extra RAM on the video card?)
    These video cards with "more RAM than standard versions" don't do anything for gamers. In fact, you really are wasting your money if you only use them for games. This is because of the way games are written. (Remember: Developers need to code for widest user base to maximize profit; and not everyone has a 1GB video card. So it would be of little use to optimize for that.).
    It DOES do quite a bit for those coding with Nvidia's CUDA...When you use Geforce as a GPGPU, the extra RAM helps. Last I checked, Folding@Home GPU2 client is written/optimized with CUDA. (So its no surprise that it does quite well in the amount of teraflops it produces in this scenario).
    This is why the 1GB version kicks butt in Folding@Home but offers very little benefit in games.
  17. SchizoFrog
    5 May 2009
    @aussiebear...
    I was under the impression that more RAM benefitted resolutions over 16x10... but I suppose it is more of a case balance... you do need more RAM but you also need a better GPU so the two go hand in hand. Hence why the higher GPUs have around 1GB minimum memory... I wouldn't have said it the way have, I think that is misleading, but I believe I get your point.
  18. misterbuggerlugs
    misterbuggerlugs What's a Dremel?
    25 Sep 2009
    A word of warning with this one. It has the identical silver and blue topped crappy capacitors on my Jetway 8600 GTS. These are substandard cheap capacitors which do not contain the preservative required for long duration gaming. The ones on my 8600 blew recently whilst playing wolfenstien. whilst the card does still function with capacitors with wadding hanging out of them it does not bode well seeing them being used on other new cards.
  19. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    remember running 820 core on the original 9800gtx.. that was a very stable oc too =] before the die shrink on the stock cooler (after a re-tim)
    it was a good card for lower res- like cod4 would play maxed at 16q aa 16x af at 1600x1200 never lose a frame
    but it absolutely blew at crysis.. and you couldn't supersample like on the old g80.. we saw the bigger memory fall flat on the 8800gt too, and they are pretty much the same card
Tags: Add Tags
