Other Galaxy S2, Deleted app...what was it?
Discussion in 'General' started by adzc1987, 16 Aug 2012.
  1. adzc1987
    adzc1987 Member
    19 May 2011
    I managed to acidentally delete an app last nite, im not sure what the app was.....is there anyway i can check a log or something and see what it was
    :S
    Lol
  2. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    There might be a specific App that could help. Have you tried searching for such an app?
    EDIT: After a quick Google search there is an app called "Undelete," but it's only for rooted Android phones.
  3. Shirty
    Shirty Time travelling rogue Super Moderator
    18 Apr 1982
    If you don't know what it was then the chances are you don't use it anyway :)
  4. faugusztin
    11 Aug 2008
    If you had it installed through Play Store, then it will be listed in My Apps in the ALL section, with "Free" (previously installed free app which is not installed now) or "Purchased" (previously installed paid app which is not installed now) label instead of "Installed" (up-to date installed up) or "Update" (installed app not updated to latest version).
  5. adzc1987
    adzc1987 Member
    19 May 2011
    Im sure i will find out one day when i need it, just curious lol.
    Yea i know i can see from the store but i cba comparing whats on the phone and what i have downloaded. And some have been installed via PC anyway.
    Cheers
  6. adzc1987
    adzc1987 Member
    19 May 2011
    Hah! Just discovered what it was. My app for syncing photos etc with my PC! Just went to do it and cant find it lol.
