Modding Gallery: Kittenmoi -A Hello Kitty themed PC for my wife -Warning: lots of pink
Discussion in 'Modding' started by ZapWizard, 7 Dec 2004.
  1. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Before you burn me at the stake, this PC is built for my wife, I told here I would build Her a PC with what ever theme she wanted.
    She of course choose Hello Kitty. :duh:
    (I wanted to build a nice clean silver/white combo)
    The PC has actualy been mostly complete for a year, with a few bugs that I hadn't had time to work out until now.
    I decided to give the entire PC a refresh this month.
    The goals:
    -Hello Kitty Themed
    -Easy to use computer
    -Internet and e-mail mostly
    -Wireless connectivity
    First the specs:
    -AMD Athlon XP 2800+
    -Shuttle Barebone system
    -512MB PC3200 DDR
    -64MB Graphics Card
    -Apple Airport express used as a wireless bridge and USB print server
    -60 GB harddrive
    -24X Slot Load 16X CD-ROM Drive
    -17" Monitor
    -USB keyboard
    -Microsoft wireless mouse
    Since my wife's PC is setup in the living room I lined the case bottom, and shell with akasa sound deadening material. Speedfan was also used to regulate the CPU fan inside the case.
    For the front of the case I wanted a simple lit button.
    With normal vandal resistant switches costing upwards of $20 I choose a simpler route.
    I took a normal door-bell switch which uses an light bulb inside...
    I then replaced the light bulb with a super bright white LED...
    The new LED provides a soft blue/white glow.
    The button remains lit when the system is on, and glows half-as bright when the system is off.
    Diodes and resistors were used to isolate the LED from Switch function.
    After a lot of krylon fusion paint, and clear coat the result is a whole lot of pink. More then my taste, but my wife likes it.
    The faceplate is super simple, with only two switches: CD Eject (top) and Power (Bottom)
    The faceplate is clear lexan, painted pink on one side, etched, and aluminum tape behind the etch.
    The end result is a near totally silent PC that is perfect for internet and e-mail.
  2. Kensei
    Kensei What's a Dremel?
    26 Sep 2004
    My God.... I dont know whether to cry or cheer.
    Beautiful work, but I can hear your soul screamer because of the subject matter from here :D
  3. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    As always, very nice ZAP. :thumb:
    You should make a Candy PC... :D
  4. TroubledMind
    TroubledMind What's a Dremel?
    9 Aug 2004
    I think it is a great looking case and that it is well suited for it's use. I think that the etch and the slot load CD-ROM just make the entire case what is.
  5. greywolf
    greywolf What's a Dremel?
    15 Oct 2004
    Very Nice, super clean. Really like your button solution. I can understand about the "pink", my current project is for my daughter and is very pink :).
    Yours is nicely understated and "soft", your wife must love it! And all the accesories match :)!
  6. ZapWizard
    19 Sep 2002
    I need to get my camera next time I order pizza, as the PC is viewable from the front door, and you should see how many "Where do you get a pink computer?" looks I get. :eyebrow:
  7. woodshop
    woodshop UnSeenly
    14 Oct 2003
    /me smells a doorbell button CCTV mod next
  8. ZapWizard
    19 Sep 2002
    Good idea, although I am in an apartment with no doorbell.
    I am thinking of trying a peep-hole camera, or just mounting it outside.
    Ironicly my neighbor that I never see, already has a camera on his door, and I know he has PC setup as he leaves is 802.11g linksys router open.
  9. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    nice job, i dunno if this belongs in the modding section or project logs, but it's nice. good job with the doorbell buttons, how do you get it to stay lit even when the pc is off? do you suck power from the CMOS battery?
  10. ZapWizard
    19 Sep 2002
    It's just modding, as it is complete.
    The LED pulls a little power from the motherboard switch monitoring circuit. (+5volts standby)
    Just a side effect of having the LED wired with the switch.
    Here is my ASCII schematic:
    Code:
    +5volts-----Diode----Resistor---Switch(pin1)---LED---Switch(Pin2)---GND
    Motherboard Switch header---Diode--Switch(pin1)--LED--Switch(Pin2)----GND
  11. Alvin
    Alvin Guest
    :thumb: Very, very nice modding job :thumb:
    As always well themed, with just the right balance to simply looking super great.
    I bet she loves you for giving her what she wanted :D It so warms the soft part of my heart to see when this happens.
    I must however admit, that it does hurt my eyes to look at it for too long at a time. :cooldude:
    It may have something to do with one of my fathers favorite statements: "I love every color ..... so long as it is green"
  12. ShagBeard
    ShagBeard What's a Dremel?
    8 Oct 2003
    LOL you even painted the remote wonder...
    i would be interested in knowing exactly how you did that...youd have to keep it fairily simple though, im not any kind of electronical guru. :worried:
  13. Infraggable Krunk
    Infraggable Krunk What's a Dremel?
    7 Mar 2004
    id kick you squy in the nuts if it wasnt for your craftmanship :thumb:
    but the moment I see a lackluster hello kitty case,
    BAM , im bringing hell :miffed:
  14. LockmanX
    LockmanX What's a Dremel?
    8 Jun 2003
    How bout bringing that to the next big LAN with your other projects? :D
  15. Tos
    Tos What's a Dremel?
    25 Oct 2004
    Excellent work, pal ! :)
    Just out of curiosity - no need to read between lines or look for hidden meanings ;) - is you wife chinese or taiwanese ?
    I'm just trying to verify a point, which is : "Hello Kitty is only popular with little (asian?) kids or chinese/taiwanese women" :D
    I already know like a dozen hello kitty addicted chinese women actually ;)
  16. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Great work!! Next time, maybe a Doom 3, hello kitty flashlight mod hehehe
    Light buttons mod is very useful.
  17. ZapWizard
    19 Sep 2002
    You and me both.
    Actualy I painted that a while ago, but she never use's it, so I am going to re-paint it silver for use with my HTPC.
    I plan to be at TXGF, maybe I will just try and bring all my current mods.
    Half-filipino
    I have no idea why she loves hello kitty so much besides "It's cute" Along with stuffed animals, and Precious Moments. (The entire Christmas tree is that stuff)
  18. RAVFE
    RAVFE What's a Dremel?
    6 Dec 2004
    one of my friends filipino girl friends is also into hello kitty, i think the epidemic has spread futher than taiwon and china.
  19. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    rafve hello Kitty is was created and originally sold in Japan. In an interview even the company president admitted he had no clue why it was so popular. It's just a Brand, There's no meaning behind it. Anyways nice work zap, you seem to have a love affair with those shuttle cases that's what 2 or 3 shuttle mods now?
  20. ZapWizard
    19 Sep 2002
    Actualy the Hello Kitty PC was the first shuttle I owned (Won it at QuakeCon '03)
    The other two PC's were demos PCs for companies, I choose shuttle as they provided the parts, and they are small and easy to ship.
    Personaly I use a Coolermaster tower for my main PC, and a AMD G-Mono tower for my HTPC.
